โNov-19-2014 08:27 AM
โNov-20-2014 03:41 AM
Canadian Rainbirds wrote:
A lot depends on wheel/brake size. I learned to drive in British Columbia and am quite comfortable with mountain driving.
Years ago we drove our 30' 1997 Triple E Commander, on a Ford 460 chassis down the Espinazo del Diablo (Devil's Backbone) in Mexico, from Durango to Mazatlan. From 6,000 feet up to 9,000 ft, down to 6000 then back to 9000 then to sea level.
At one of the very few places to pull off I stopped for a "rest" break. Bad mistake. With no air moving past the wheels the drums on the 16" rear wheels heated the brake fluid to the point that there was vapour instead of fluid in the brake system. I pulled out behind a bus and braked for the corner and the pedal went to the floor :E Fortunately I was still going slow enough that I could pull it into 1st gear. A lot of pumping on the brake pedal gave me a little (just enough) braking. After following the bus downhill and pumping like mad when needed I regained reasonable braking in about 20 minutes.
We now drive a small (32') diesel pusher with 22.5" wheels, airbrakes and a great Allison 6 speed an excellent cruise control and exhaust brake.
โNov-19-2014 09:58 PM
โNov-19-2014 09:56 PM
rgatijnet1 wrote:
redguard just sent me this as a PM in reference to my post where I said that gasser RV's have no problems in the mountains with either the climb or the descent.
"you obviously have not driven a larger A gasser loaded in the rockies etc as this statement is pure bunk simply put UNTRUE "
I'll let those of you that have driven their gassers in the mountains respond. I have never had a problem with my Monaco gas coach in the Rockies, but I also never had a problem with the diesel coaches I've owned in the mountains.
Apparently he wanted to call me liar in private. Oh well! :B
As the above posts already seem to indicate, gas RV's do fine in the mountains.
โNov-19-2014 09:42 PM
โNov-19-2014 09:01 PM
โNov-19-2014 08:41 PM
โNov-19-2014 08:31 PM
Porsche or Country Coach!
โNov-19-2014 08:24 PM
โNov-19-2014 08:15 PM
kgard1225 wrote:
Thanks for all the replies. I wasn't sure if the engine rpms would get too high going down a steep descent keeping in a low gear. All of the late model gassers I have been looking at had Ford chassis with the V-10. What is redline on these motors ?
โNov-19-2014 05:24 PM
RayChez wrote:
Yes gasoline motorhomes with big engines have lots of power, but man they eat gasoline like crazy. I had a 454 chevy pickup with a big overhead camper. I started climbing the Sierra's from Bishop to Mammoth. It went up easy, but I was almost out of fuel by the time I got to the top of the mountain. LOL! And the Ford 460 was even worse.
โNov-19-2014 05:19 PM
โNov-19-2014 04:25 PM
โNov-19-2014 03:16 PM
โNov-19-2014 02:37 PM
โNov-19-2014 02:07 PM
