โNov-18-2015 06:23 AM
โNov-19-2015 06:16 PM
j-d wrote:I've "snipped" some wise comments from the excellent write-up by j-d. I should have expanded my comments. I drive a Chevy, so the rim holes are different than the Ford rims. Midwest Tire handles pickup, semi's, and the Class 5 and 6 trucks like you find on U-Haul lots and for furniture delivery trucks. So, I don't really know what the bins of straight and curved stems fit. I know the ones they used fit my Chevy rims just fine. ๐
Let me say again:
JUST GET SOMETHING THAT WON'T LET YOU DOWN!
Gene was fortunate. The truck shops I checked at couldn't give me what Gene got.
1. Domestic "Big Trucks" use a .625" hole in the wheel for the valve. Class C's, Cars, Pickups, etc. use .453". Some valves come with both gaskets, just be sure what you get fits .453".
Friends Don't Let Friends Use Rubber Tire Valves!!!
โNov-19-2015 01:02 PM
โNov-19-2015 12:38 PM
โNov-19-2015 12:15 PM
โNov-19-2015 04:41 AM
โNov-18-2015 06:22 PM
TwoPines wrote:Many of us have had the exact same concerns and have found a few ways to solve the problem. However, adding an extension piece usually will either have a slow leak or will break off the original rubber stem. We drove our RV to Midwest Tire Store that sells truck tires. Not tires for pickups, but for the 18 wheelers. Those trucks have a number of duals with the same problem. Midwest had bins full of the longer straight stems and the "u" shapped ones. You could select from brass or chrome. They were cheap - like $2 to $3 each. I had called them before driving down there and they knew exactly what I needed. I waited about 20 minutes and they were done with all 6 tires. They merely used a floor jack, raised the wheels in the air, used air guns to remove the lug nuts, took the wheels to the tire machine, broke the beads, threw away the old rubber shorties, put in the curved chrome stems, aired up the tires, mounted them and dropped the RV on the ground. Charged $10 per tire plus the $3 stem. Total cost about $80. They had done it hundreds of times before. ๐
Looking for suggestions about options for adding air valve stem adapters on dual rear wheels? Bought a Jayco E-350 Class C with 225/75 16" tires a few months back and while winterizing noticed that the valve stems on the dual rear wheels are located between the two tires. So, unless I dismount the outer tire, I can't check tire pressure on either tire, nor can I add air if needed. Are there types of adapters preferred or are there replacement stems or what options are there? I would rather have an idea about what I need before going to the tire shop for a fix.
Thanks in advance.
โNov-18-2015 05:39 PM
samven1 wrote:
After doing all the research several months ago and deciding I needed the one piece valve stem and then calling around for someone to remove my tires to install them I went with a TPMS that has an in cab display. I still have to pop the hub caps to add air which is a pain but it is really nice to just flip the monitor on 5 min before I leave and read the tire pressure and temp of each tire. It is also very informative to see the temp and pressure change as you heat them up and one big surprise was watching the right hand side heat up and pressure rise going across SD with a strong wind from the left. In the 6 mos I have had them I only had to add air once because of the dropping temps and double check the monitor accuracy against my digital gauge.
They do all read 2 psi lower than my gauge but I am not sure which one is off since 2 psi is within the spec of both.
โNov-18-2015 05:38 PM
โNov-18-2015 04:19 PM
โNov-18-2015 02:09 PM
โNov-18-2015 10:15 AM
โNov-18-2015 10:11 AM
โNov-18-2015 09:18 AM
โNov-18-2015 08:15 AM
