Frig does not get cold on electric?
Big_Redneck
Its a 1995 Dometic frig. I have it on gas now to see how it does. Its looks like it ok on gas. I will check the temp in a hour. It may be the circuit board but not sure.
We don't travel as much as we use to. I guess we are getting old.I want to go out west one more time.
11 REPLIES 11
Big_Redneck
I got one somewhere now to find it. Thanks
littlemo
Had this problem and my converter was bad.
Dakzuki
First item: Check for AC voltage at the outlet the fridge is plugged into. It could be something as simple as a GFI popped. Get one of these and keep it in the RV.
2011 Itasca Navion 24J
2000 Chev Tracker Toad
Big_Redneck
Dometic Model RM2611 I have it turn off now.
DaHose
What model fridge?
Old-Biscuit
So other than swapping to electric from propane have you checked any of the suggestions for WHY electric doesn't work?
Big_Redneck
The frig works very well on gas. Last night I switch over to electric and this morning the ice trays were melted and not cold.
wbwood
How long did you wait for it to cool on electric? An hour or two is not long enough. You will more than likely need to wait pretty close to 12-24 hours. Propane will cool it faster.
Brian
2013 Thor Chateau 31L
Old-Biscuit
Cools on propane but doesn't on electric....
Check for 120V AC at outlet fridge plugs into
Check 5A fuse on lower control module......it is for electric heater
Unplug electric heat element.......check resistance approx. 44 ohms
1994 vintage...probably needs new element (and fuse)
ScottG
Make sure the outlet at the back has 120V coming out of it.
Toddupton
Or something as simple as a bad heating element. Put it on elec and see if the element heats up or has voltage.
