โFeb-03-2015 11:07 AM
โFeb-07-2015 03:59 AM
โFeb-06-2015 08:53 PM
Islandman wrote:
The 160,000 km referred to is just under 100,000 mi which isn't too high for a 6-7 year old unit. But as others have noted, it is high for the price they want, and stuff is going to wear out sooner that you may expect because of the relatively high use in the 6-7 year life.
โFeb-06-2015 07:46 PM
โFeb-06-2015 06:17 PM
GasCap9000 wrote:
Hello guys,
I am looking at buying a 2009 four winds majestic 19G ~160,000KM. asking price is $29,485. does this seem fair? I am looking to shave 20% off that, do you guys think that is realistic in the Canadian RV market?
I have no RV experience and this would be my first RV purchase. Could you guys give any insights on how to negotiate prices, what to look for in terms of
inspection - new tires/parts and should I get a different dealer to get the RV?
Price - 10 , 20, 30% off asking price?
is there anything I miss?
Thank you guys for all your inputs!
โFeb-06-2015 06:10 PM
GasCap9000 wrote:
Hello guys,
You said "160,000" kms. I know something about buying an ex-rental. Canadream has some good units and others too but that is very very high mileage for a rental. If it had 80K ok. They do service them well and have full records but this unit sounds 'suspicious' to me.
IMHO
โFeb-06-2015 03:45 PM
GasCap9000 wrote:
I just called Travco, They said they only do water leakage inspections. no Chassis or automotive. So looks like I would have to bring the RV to multiple shops to get EVERYTHING checked? is it necessary to get everything checked?
โFeb-06-2015 02:25 PM
โFeb-05-2015 04:24 AM
GasCap9000 wrote:
Solar panel is my top priority add-on. Will definitely get them to install one for me. Also because of the noisy level on solar panels NONE! I believe there are no quiet generators with my research...
Go west told me it is 5500 to install a generator... I am pretty sure a top solar setup will cost me about ~2500? Max Out
โFeb-04-2015 07:34 PM
โFeb-04-2015 06:14 PM
Lynn0527 wrote:
Yes much, now keep in mid that I have to pay to get things installed. You may be one of those handy guys. I bought a Renogy 100 watt suitcase solar panel that I am very happy with, a plug and play to keep the house battery up. I like the solar so much that I want to get another panel put on my roof. Canadream will do it for $800.00 - 20%. I think that is a good price as I was at the RV show and their show prices were about $650 installed for a 120 watt. I was quoted $3200 for an installed generator. You can purchase a stand alone generator for less and that might be an option. I like the idea of solar better.
Lynn
โFeb-04-2015 05:39 PM
GasCap9000 wrote:garyhaupt wrote:GasCap9000 wrote:garyhaupt wrote:
Gary Haupt
thanks for recommending a inspection shop, I looked into a few shops and didn't know which one is reputable.
When do I I bring up independent inspection with the dealer? and if the inspection found parts needing to be replaced. i should negotiate with the dealer for them to fix anything to working condition?
I want to ask you to be sure you can afford this thing..not 'this' one, but any one. The buying is only the first step to a huge financial commitment. I am not asking for your financials...just asking that you understand what you are getting into. Filling the tank is well over $140.00 and you would need two or three fills to get to the Okanagan, say. And then you have to get back. If or when a fridge, furnace, hot water tank need replacing, you are looking at an easy grand..and more. I am not trying to scare you off purchasing. If you can afford to use it, it is truly one of the best ways to go. But...there are lots out there that get bought and then never move.
And...we haven't even touched on power yet...with a motorhome you have to have power. There are only 3 ways to do this..generator, solar or plug-in. The unit you are looking at was for the plug-in market. It won't have a generator..either built in or portable. You will need to think on this. If you too are going to plug-in, that means private RV campgounds. Not out in the boonies camp grounds (prov park ones). Yes, you will have A battery...you will need at least two for most weekends and even that is pushing it. If you go see Kevin at Travco...ask him about power. Don't tell him I said to..I am slow and stupid and he had to talk to me several time before I 'got it'.
Gary Haupt
affordability is not an issue, I am fine with money spent on gas. Definitely not on replacing big ticket items... That's why I would definitely want to get it inspected and try to get them to replace all small/big items if possible... I do understand that there will be yearly maintenance costs this I am also fine with.
I do wish to go to places that are more remote. Would installing Solar panels solve the power/battery issue? I heard installing solar is cheaper than installing generator.
โFeb-04-2015 02:51 PM
Gary Haupt
Gary Haupt
โFeb-04-2015 08:38 AM
โFeb-04-2015 07:30 AM
Gary Haupt
