โFeb-28-2017 06:03 AM
โNov-11-2017 08:18 AM
โMar-01-2017 11:14 AM
No state requires an actual CDL for personal noncommercial use of RVs, though several do require noncommercial licenses beyond the standard driver's license and frequently the requirements and classes of such licenses parallel the ones for CDLs. (General CDL requirements and applicability are determined at the federal level.)
If the OP is home based in AZ I believe that state does require a class "B" endorsement. This will be due to the weight of the motorhome being over 26,000 lbs not length and frankly even any 40' will be over that. KS requires the same and it is super simple/easy to stay compliant.
โMar-01-2017 07:50 AM
โMar-01-2017 05:15 AM
โMar-01-2017 04:44 AM
โMar-01-2017 04:25 AM
โMar-01-2017 01:42 AM
โFeb-28-2017 06:41 PM
2gypsies wrote:DrewE wrote:
The District of Columbia prohibits them entirely.
This and others I looked up says District of Columbia does allow RVs.
http://www.godcgo.com/home/tools-for-getting-around/other-resources/freight-management/oversize-and-...
โFeb-28-2017 06:14 PM
โFeb-28-2017 05:56 PM
TheLostDutchman wrote:
Thanks for all the advice and info... It got me to looking up restrictions - we intend to spend a lot of time in Alaska which means going through Canada... Maximus length everywhere except Yukon is 12.5 meters or 41'6"...
We also want to tow a Jeep Grand Cherokee. Approximately 33 states have 65' combined length restrictions as well.... Dang. What an eye opener. Glad you all are giving me things to consider. I would have completely missed those two important points.... You all are the best.
โFeb-28-2017 04:49 PM
โFeb-28-2017 03:15 PM
DSDP Don wrote:Yeah that ๐
You may also want to check for storage and weight issues. My 40' with a tag, loses 3' of storage bay, but has a pretty much unlimited carrying capacity. So look closely at the actual storage capacity when you look at different sizes. Typically, anything over 40' gets a tag. So.....if you bought a 40' non-tag, you'll end up with two more feet of storage bay, than a 41' with a tag.
โFeb-28-2017 11:29 AM
โFeb-28-2017 10:50 AM
DrewE wrote:Ivylog wrote:
No state limits the length of MHs to 40' but some like CA require a CDL type licence for RESIDENTS if they have a 40+ MH. When I take my 42' into CA I do NOT have to have a special licence... it's called reciprocity of licence but there is no reciprocity of length. Maybe with a four door Jeep behind a 45' MH you could be over 65'. I have traveled thousand of miles at 42' (with others that were 45') in Canada and never had an issue plus I've seen a bunch of Canadian tour buses that were 45'.
Maryland restricts motorhomes longer than 40' from most non-interstate roads. The District of Columbia prohibits them entirely.
โFeb-28-2017 10:06 AM
