Aug-11-2014 06:18 AM
Aug-12-2014 09:21 AM
Aug-12-2014 08:48 AM
Crespro wrote:
x2 M&G is very solid and simple to connect the toad.
Aug-12-2014 08:20 AM
Aug-11-2014 09:24 PM
wa8yxm wrote:
For a diesel pusher since you already have your tow bar M&G
If you had not already gotten your tow bar Ready Brake (With the matching tow bar)
For MH's w/o air brakes US-Gear unified brake decelerator
Those are my top suggestions,, Next is
All the other INSTALLED systems that are BOLTED into the vehicle.
And on my NON recommended list are things like Even Brake, Brake Buddy, and so on where you put a box in the driver's seat and it pushes the pedal.
Too easy to screw up if you are in a hurry or even to just say "Forget it" and regret later.
Aug-11-2014 07:41 PM
rondeb wrote:
Stay and Play system by SMI
We have this system and it is worry free and extremely efficient.
Aug-11-2014 02:05 PM
J-Rooster wrote:I also upgraded from the 4 wire to 6 wire cable. 4 wires for the lights, 1 for battery charge and 1 to the MH dash for the toad brakes. For years I did not have the battery charge wire, didn't disconnect the fuse and never had any battery problems.CA Traveler wrote:Thanks for the info! I think I'm going with this set up on my CRV and I'm also going to run a live battery wire back to the toad!
I upgraded from a box brake to the Roadmaster Invsibrake. Absolutely nothing to do - no switches, cables, air lines or anything else. A light on the MH dash indicates the brake is activated.
There are a variety of braking systems and the above recommendations are all good.
Aug-11-2014 01:37 PM
rockhillmanor wrote:
From a Brake Buddy owner.....do NOT buy one of them!
Buy one of the automatic braking systems.
If you camp more than a couple times a year shoving that BB in and out of your Toad every time you use it gets REAL old and hard on the back.
My Toad was a Tracker and I had to just about get on my hands and knees to get that Brake Buddy in, adjusted, clamped on, tested etc.
Aug-11-2014 01:07 PM
Aug-11-2014 11:50 AM
Aug-11-2014 11:34 AM
Aug-11-2014 11:22 AM
Aug-11-2014 11:20 AM
rockhillmanor wrote:Bumpyroad wrote:
I used my brake buddy for years, worked great, not a hint of a problem.
bumpy
My Brake Buddy worked great too, but my back didn't! You must be in batter shape than me or a whole lot shorter! :B:B
Aug-11-2014 10:57 AM
bumpy
Aug-11-2014 09:39 AM
