โSep-23-2019 10:58 AM
โSep-09-2020 04:58 AM
pnichols wrote:
I'm a bit of an outlier, I guess.
Our E450 24ft Class C has handled just fine right from the time I drove it new off the dealer's lot. I've always attributed it to the chassis being well within it's specifications in carrying only the weight of a small Class C.
It's cab floor has never been overly warm, but it does have heat shields underneath between the cab flooring and the engine exhaust pipes coming from each side of the V10.
It used to ride rough in the rear, probably due to it's rear suspension having weight rated leaf springs and shocks well beyond what the loaded coach requires. I eliminated the rough ride in the rear by installing special rear shocks. I don't think of this issue as a "handling" problem, per se. Probably a stock Chevy 4500 chassis under a small Class C would also ride rough in the rear.
I'm 6'2" and can still get by OK in the cab driving and when leaving the driver's seat to go into the coach.
In other than with a Ford E450 or Chevy 4500 chassis, how's does one find a heavy duty chassis under a small Class C in the U.S.? IMHO, the other chassis types now being used for small Class C motorhomes in the U.S. can be too close to their design maximums under certain conditions when in motion.
โSep-09-2020 12:35 AM
โSep-07-2020 06:36 PM
โSep-04-2020 05:19 AM
โOct-14-2019 07:46 PM
ron.dittmer wrote:Pirate wrote:The Ford E450 and the Chevy 4500 are the only two "conventional" class C chassis that exceed 25 feet in length. Shorter models open up more chassis options such as the Ford E350, Ford Transit, Chevy 3500, Mercedes Sprinter, and Dodge Promaster.
I see many of the comments go toward Chevy vs Ford on the C. Is there any real good reason other than the Ford vs Chevy?
The Ford E350 and E450 are most affordable, most capable, and most friendly for wheel base adjustments which is why they are most popular. But they are the least comfortable, handle worse, are least fuel efficient, and are most noisy which is why the others are in the game. I personally don't find the deficiencies to be but only a minor nuisance except for the poor handling of which I was able to address our E350 rig with some aftermarket suspension upgrades. To be even more fair about it, I wonder how the other chassis' would fair if used in the exact same application with the exact same wheel base.
โOct-14-2019 04:14 PM
โOct-14-2019 03:26 PM
โOct-14-2019 02:14 PM
โSep-27-2019 04:12 AM
โSep-27-2019 02:06 AM
โSep-27-2019 12:35 AM
โSep-26-2019 10:18 AM
โSep-26-2019 05:24 AM
โSep-25-2019 08:09 PM
