Dec-21-2014 03:19 PM
Jan-07-2015 08:35 PM
Jan-07-2015 03:21 AM
Jan-07-2015 02:58 AM
Jan-01-2015 09:38 PM
Jan-01-2015 09:18 PM
Jan-01-2015 08:53 PM
Jan-01-2015 08:45 PM
Jan-01-2015 08:38 PM
Jan-01-2015 08:35 PM
Jan-01-2015 08:30 PM
jetcare wrote:
Check the outside shower. Do you have the handles in the on position? If so, turn them off.
Dec-26-2014 06:42 AM
Fleetwood Couple wrote:When I removed my relief valve to change it I had the same concerns because it was in there for 18 years. I sprayed it with PB Blaster or Kroil oil and let it sit for several hrs. Tapped the valve slightly to get the oil into the threads and it came right out.
So today I drained and flushed the water heater, water inside was at about 155 on the meat thermometer, then tried to remove the relief valve to allow me to fill the tank with vinegar/water but it wouldn't budge felt like i was going to break it. I refilled the tank and turned it back on. Water heated back up and when tested at the sink it was very hot to the touch for about 1-2 minutes then back to lukewarm. I will try again tomorrow.
Merry Christmas Everyone!
Dec-26-2014 04:53 AM
Dec-25-2014 08:38 PM
Dec-25-2014 08:02 PM
