Tips on picking, entering, and leaving gas stations
ClearCreekRanch
Ok, so yesterday in route to a horse show in Texas from Kentucky, I had an argument with a post in a Valero station. The post won and I returned home, sadly. It was one of those stations with slanted pumps and a McDonalds, i.e., too many people, not enough room. I should have known better, right. Well in my defense, I have only taken 2 short trips in my Winnebago Aspect and have owned it for only 3 months. I will never make THAT same mistake again. But my question is, how do you find the right gas station when you need it? And are there any tips that you can give me to help my confidence? I really like my motor home, but I am seriously doubting my abilities. I do fine changing lanes and driving in general, it's just the gas station thing. Another example is today, on the way to the dealership, I had gotten gas at a Pilot station(that I have used a few times) and a couple of dip sticks parked in the middle of the parking lot, only way out. So I walked over and checked it out and then went soooooooo slow between the two. I was nervous but I made it.:)
30 REPLIES 30
Old-Biscuit
powderman426 wrote:
I am opposite of many here. I avoid the truck stops like the plague. They tend to be over priced and filthy, not to mention the lot lizards and panhandlers. Especially the diesel pumps. I have yet to find a station I couldn't get in or out of But I do prefer that the lanes be parallel to the road.
You aren't alone!
If it's has a diesel pump I will use it.
Been in many stations across the USA with my longbed quad cab truck and 5vr. Ain't found one I couldn't get in and out of yet.
I've been in tougher CGs then any station
Bednarski1
I try to use Pilot/Flying J. Lots of room, big lots and if you are a Good Sam member 3 cents a gallon off the price. Like the others have said also take your time and if you have to wait then just wait.
marly
Wash your hands!
DutchmenSport
Get the App "gasbuddy.com" on your I-phone. It's priceless. Pull up the map and you can zoom right in and get a feel for the layout before you get there. Gasbuddy.com = priceless!
Dick_B
It's a challenge most every time except at truck stops. Sometimes I will drive around the building to get the end pump facing out. Makes it much easier to drive away.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
dbbls
As I approach a station I go very slow to analyze the ingress and egress. If it is questionable I go on.
2011 F-350 CC Lariat 4X4 Dually Diesel
2012 Big Country 3450TS 5th Wheel
powderman426
Ron & Charlotte
WD8CBT since 1976
32' Gulfstream Ameri-Camp & 05 Ram QC LB
I started with nothing and I still have most of it left
I never fail, I just succeed in finding out what doesn't work
rvten
Flying J when I can find one. Truck stops and use outside island. Stations where the pumps run parallel to the road. Station you can pull in and go around the building to exit.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is NO B+
past-MIdirector
A lot of people bad mouth Flying J and Pilot but they have some of the biggest swing around to the pumps. Also the RV and truck lanes are great.
grampscamper
I try to use truck stops whenever possible. I have a Garmin GPS. Garmin has free software that you can download for your computer called BaseCamp. I use it to plot my routes and find gas stations along the way. I make waypoints for fuel stops to transfer to my GPS. I also use Google Maps & street view to see how accessible the gas stations are. Once you make a waypoint you can cut & paste the coordinates into Google Maps for a street view.
2019 Grand Design Reflection 230RL
2020 Ford F250 Lariat CC SB 4X4 6.7 B&W Companion RVK3300
obgraham
My routine: Stop before I enter the service station. Get out and walk over, check the space requirements. In my case I have to find a diesel pump which has the small "automobile" nozzle, not the high speed truck nozzle. At truck stops it is more likely to be on the end of the row.
PghBob
I always try to get the end pump island, so I have more room to turn and (usually) have more clearance for the rear-end swing. When on main highways, I usually try to use truck stops. Like posted earlier, when we find a good stop we write it down in our trip log.
Bob
yrusoslo
That's why I like truck stops!!!
Capt_Storm
Swing wide and always take your time..others can wait if they have to.
lots2seeinmyrv
Before our trip I use findfuelstops.com
Put in starting point City, ST...then I put in a City on our route about 300 miles from there. (we start looking for fuel at 150 miles around a half tank).
findfuelstops will post each gas station on your route, how many miles to it, and you can pull up the "satellite" view of the gas station to see how to get in and out of there.
A lot of times...we find that a lot of them we can't get in and out easily so this has been helpful for me to do for my DH.
I write the stations and exit numbers down in my spiral notebook and it works for us.
