towing a Jeep with aftermarket bumper
Mikeborny
Recently bought a 2015 Jeep Unlimited Sahara with a Barricade after market bumper. Blue ox said they only needed the plate thickness of where the "d" rings attached and the hole size for the d ring pin and they could modify a bracket. has anyone towed a jeep with the bumper and not the base plate?
2014 Forest River Berkshire 390bh-40
hauling 2 Berners,3 kids
13 REPLIES 13
mowermech
JimM68 wrote:
we towed a TJ with these for years clicky
I bolted them to my aftermarket bumper prior to bolting the bumper to the jeep.
The brackets that came with the Reese fixed-arm adjustable width 5000 lb. capacity towbar ($145 at Walmart) I used are very similar to those. I used that bar on various Jeeps over the years, both on stock and custom bumpers. Yes, I used adequate (1/4 inch cold rolled steel) back-up plates.
No problems.
CM1, USN (RET)
2017 Jayco TT
JimM68
Jim M.
2008 Monaco Knight 40skq, moho #2
The "68"
My very own new forumfirstgens.com
My new blog
Mikeborny
Thanks for all the replys! Looking at $2900 for avail towbar, and air force one brake system installed. Hope to have everything ready for Christmas vacation!
mnoeltne
I've towed our Jeep for a number of years with a custom bumper. The bumper I have actually uses more bolts than the tow bar brackets would have used, and is quite a bit stronger.
Mark & Joyce Noeltner
2005 Fleetwood Fiesta 26Y
2001 Jeep Cherokee Sport
jsmart
Replaced the stock bumper on our 2009 wrangler with a Smitty built with 'd'ring points that I mounted a Reese rigid tow bar to. This allowed me to bolt directly to the two front frame points. Worked great with no issues for over 4000 miles of towing. Unfortunately, don't have jeep anymore.
2002 Itasca Sunrise 32V
dahkota
We also have a Rockhard bumper. We have towed from Florida to Alaska, including the Dalton Highway. We have had no issues what so ever with towing and prefer the bumper to a baseplate for two reasons: it doesn't decrease our jeep ground clearance and we don't need a drop hitch on the motorhome.
2015 Jeep Willys Wrangler
2014 Fleetwood Bounder 33C
States camped: all but Hawaii
more than 1700 days on the road
Gig_em
I put a Rockhard bumper on ours. They have a bracket built for Blue ox. It screws into the frame where the bumper attaches. I wouldn't think bumper thickness would be an issue since it's not screwed into the bumper. Several of the bumpers I looked at had D rings in the way for this bracket and can't be used.
http://www.rockhard4x4.com/product_p/rh-8000-bo.htm
egh33
Some years back my son-in- law towed a jeep with just the bumper , no base plate. On his way to the garage with the Motor Home for some repair and took the jeep so he could go to work from the garage in Ft.Worth the bumper came off the Jeep and was trying to pass him on the passenger side. Lucky for him the Jeep hit the curb and turned the Jeep wheels into the curb and stopped itself.
FIRE_UP
Mikeborny,
Folks have been towing Jeeps with aftermarket bumpers for decades. Most of the needed info you're looking for has already been explained. After towing 7, and soon to be 8, Jeep Wranglers all over this nation, WITH AFTERMARKET BUMPERS for thousands and thousands of miles, without ever having ONE WELD FAIL, I will keep on doing it.
Many of the aftermarket bumper builders use a standard D-Ring shackle tab welded on to the front bumper, on each side. Well, Blue Ox makes an adapter that adapts their tow bars, to those D-ring tabs. Yep, they run about $250 plus or minus but, while in my opinion, that's a serious rip off, it is a BOLT ON deal and, once on, you're done and, are towing down the road.
Once you're at your destination, the adapter brackets are removed with the tow bar and, the D-ring shackles, if you have them, are back on.
Scott
Scott and Karla
SDFD RETIRED
KI60ND
falconman
Our 06 Wrangler has a Smittybilt bumper with D Ring attachments. I use the BO adapters to attach the tow bar. The adapters are expensive but well made and work fine. You need to know the diameter of the pins on your bumper D Ring, either 7/8 or 1 inch. The D rings should be welded on both sides of the bumper for max strength and make sure proper grade bolts were used to install it.
jolooote
The problem with Aftermarket bumbers is that they use all the same bolt points that the baseplate makers wanted to use. Can only bolt on one or the other. Be aware...hitch makers no longer weld hitches on because welds can fail.
Joe & Charlotte
2020 Jayco Greyhawk Prestige 29MV Celestial Blue Full Body Paint E-450 305hp V10 6spd Class C 'COACH'
2012 Jeep Wrangler 285hp V6 'TOAD'
Gabby & Molly are Dogs
Leroy's a Conure, Loretta's a Squeaker
"Once it starts breakin'...GET RID OF IT!!!"
Mikeborny
Blue ox makes an adapter that fits the bumper but they want $250 for it. The entire baseplate is $390 i think. Although there will be no labor involved with bracket!
Thunder_Mountai
Yes, I had Tomken in Buena Vista, Colorado modify one of his standard aftermarket bumpers to have Blue Ox mounts in place of the standard recovery D ring mounts. With a bit of grinding on the D rings, they will fit on the Blue Ox mounts when not towing. The bracket plate is welded to the bumper and bolted through the bumper directly to the frame. His price was competitive with comparable aftermarket bumpers.
2016 Winnebago Journey 40R
2018 Rubicon
1982 FJ40 Toyota Land Cruiser
2020 Keystone Outback 327CG
2020 Dodge Ram 2500
Polaris RZR XP 1000
4 Cats
3 Dogs
1 Bottle of Jack Daniels
Two old hippies still trying to find ourselves!
