Toyota is working on a mini monster truck.
magnusfide
It's not a truck camper because it doesn't slide into the bed. But it looks like one. Toyota seems to be reviving their old Chinook concept with off-road capabilities. We'll see if it becomes reality with today's gas prices.
The Toyota 'Tacozilla' is the coolest off-road camper you'll see today
"The only time you should fear cast iron is if your wife is fixin' to hit you with it."-Kent Rollins
First law of science: don't spit into the wind.
Magnus
12 REPLIES 12
magnusfide
coolmom42 wrote:
Nothing prevents it from being a daily driver. All the advantages of a truck camper, without the high entry price of a truck plus slide-in camper.
I was thinking that as well. It does have access to the forward cab according to the photos. It could even be a version of a mini-van if the seats have belts.
Magnus
coolmom42
I want one!
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
VA-Apraisr
No access forward to the cab either....wet bath (ughhhh).....tiny, tiny, tiny.......would rather have a slide-in truck camper which does require a truck, but, at least you have a pickup truck to use. Don't see it in my future.
magnusfide
More on the "Tacozilla". Shows the interior with its full bathroom and gives more details on the construction.
"The team also added a two-inch suspension lift, snorkel air intake and a winch integrated into the front bumper."
Link
Magnus
RobertRyan
I had a 1988 Damon Escaper built on a 1987 Toyota one ton with a 22Re (4 cylinder) engine. We sold it with 68,000 miles on and it ran great. The biggest complaint was that to get up steep climbs, we had to be turning 4500 to 5000 rpm's to make power. Going up the west side of 14a (going east) we had to stop at a restroom about 3/4 of the way up. I forgot to stop with the RV pointed downhill in the parking lot. The engine did not have enough power to pull
Problem with a basic Toyota frame and suspension. As well the small petrol engine would not pull very well. Toyota 1 Ton is another name for a very early Hilux
These were replaced by the downrated Tacoma
RobertRyan
There are about three RV manufacturers in Australia that build similar. Here is Explorer Motorhomes
BarabooBob
Just remember that Toyota NEVER built a single RV. They sold the cab & chassis units to companies that built RV bodies on what was originally a 1/2 ton truck frame. After a major law suit, they started selling one ton dually C&C frames and Toyota PAID to fix the problems that American manufacturers created by making the RV way to heavy for the light weight axles on the 1/2 ton trucks.
I had a 1988 Damon Escaper built on a 1987 Toyota one ton with a 22Re (4 cylinder) engine. We sold it with 68,000 miles on and it ran great. The biggest complaint was that to get up steep climbs, we had to be turning 4500 to 5000 rpm's to make power. Going up the west side of 14a (going east) we had to stop at a restroom about 3/4 of the way up. I forgot to stop with the RV pointed downhill in the parking lot. The engine did not have enough power to pull ahead from a dead stop, I had to back up and turn around to get a running start to finish the climb.
I loved the little truck but would not give you $100 for another one even in great shape.
Bob & Dawn Married 34 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
monkey44
Nomad II
Nomad II
Predicted Price - $53,000.
Toilet ... maybe a Cassete?
If you boondock a lot - No shower ...
Might be able to use a flash WH, and outdoor shower.
Pretty compact ... a go anywhere camper ...
Price is not compact tho'... 🙂
Monkey44
Cape Cod Ma & Central Fla
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
Back-country camping fanatic
jimh406
Yep, Class C like the old little ones were. Should be moved again … oh, well.
Grit_dog
Navigator
Navigator
Cool!
d3500ram
Class C?
Sold the TC, previous owner of 2 NorthStar pop-ups & 2 Northstar Arrows...still have the truck:
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
Moderator
Moderator
Moderator
Moved from ATC
