US 30 West from Longview to Astoria OR
pmedic
I understand there is a 7.0% 2 mile uphill grade soon after crossing the Longview bridge into OR. I have a Gasser Tiffin Allegro 34 TGA Ford V10 engine pulling a 4400lb CRV. Should I take Hwy 4 on the Washington side instead of Hwy 30 on the OR side? I am on a time schedule to get to Rockaway Beach so the shorter the route, if doable, the better. If 30 is not a problem, should I unhook the toad? Thanks in advance for the replies!
11 REPLIES 11
mustang652
On last trip from Texas I pulled several long 7% grades towing an '07 Focus. No problems.
Stan, Shirley & 2 Schnauzers
RV: 2014 Itasca Sunstar 35F
USAF Retired, Life Member: VSPA, VVA, DVA,VFW
jsmart
I would use Hwy 30, the Washington side is longer and narrower. The hills you have to pull are not going to be a problem. Have fun.
2002 Itasca Sunrise 32V
Executive45
pmedic wrote:
Thanks for all the replies! We will give it a go but will dc the toad for the main climb. Thanks again!
pmedic...after you cross the bridge and make the right hand turn, there is a huge pull off spot overlooking the bridge. If you decide to unhook, (which I think will be unnecessary) you can do so there. It's a great photo op also....Dennis
They say a picture is worth a thousand words...here's a couple thousand...D
From the pull out spot...
This is the pull out spot...
pmedic
Executive45
We did it with no problem....enjoy the trip..pull off just after the bridge for some awesome pictures.....Dennis
gjwarneke
We made that route in July coming off the Longview bridge going to Astoria, we just had our tranny beef up with a shaft kit, deep pan cooler and a three stage converter and wanted to see how it pulled hills, that was the only hill around the Portland/Vancouver area that would give it a good test, our 7.3 Ford pulling a 15,000 40fter 5er did better then I thought, maintained 45mph, but that torbo was howling!! and the one post was right, you can't get a run at it off that bridge. The other hills seem alot easier coming back from Astoria. Next test was going down that 7% grade to see if second gear would hold back that much weight, held it at 50 with a couple brake applications.
I know this doesn't have anything to do with the first post question, just had to say........next is Cabbage Patch Hill out of Pendleton Or.
J-Rooster
I recommend Hwy. #30 to Astoria it's faster then the Washington Side. Before I retired I would use this route going to the Port of Astoria from Seattle in my semi and, I've used it many times in my MH with toad, going to Seaside, Ore.
capnqball
Hundreds of RV's use Hwy 30 to Astoria. The grades you encounter are not that long to be a big problem. The Washington side is slower and longer. I live just off 30 and go to the coast numerous times a year.
Drive safe.
Ron
Scappoose OR
enblethen
US 30 is not the bad. It is a pretty easy climb. There is actual two climbs. One near Longview and another near Wauna.
One by Longview bridge is the harder one as you cannot get a running start.
The one by Wauna is easier as you can see it and get a little running start depending on traffic.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
amandasgramma
We've done it with a gasser (30 ft) and a dp (36 ft) many many times. Family in Clatskanie. I do NOT recommend Hwy 4 - it's longer and narrower. Many people do it.....including semis. You can do it....go for it.
My mind is a garden. My thoughts are the seeds. My harvest will be either flower or weeds
Dee and Bob
plus 2 spoiled cats
On the road FULL-TIME.......see ya there, my friend
sgip2000
US 30 isn't that bad. Many trucks use that route. You could also use US26 to US101, but you'd have to climb either way.
