Feb-18-2016 11:31 AM
Feb-19-2016 10:16 PM
Feb-19-2016 08:55 AM
Feb-19-2016 08:46 AM
Feb-19-2016 05:14 AM
roachcoach wrote:
OK I need some help with the electric and propane switch . Where do I start to check why the switch doesn't light up. First of all the electric water heater is working just fine except for the light. The propane water heater is not.
Feb-18-2016 08:14 PM
Feb-18-2016 06:29 PM
Feb-18-2016 05:54 PM
GPWayne wrote:
As you said the electric water heater is working just fine except for the light.
The bulb in the switch is burned out...This is very common. Easy fix, replace the switch.
The propane water heater should not start if the tank is full off hot water,,,,, heated by the electric heater element.
Feb-18-2016 05:21 PM
Feb-18-2016 04:36 PM
roachcoach wrote:
GCH10A-4E Atwood
Feb-18-2016 02:17 PM
Feb-18-2016 01:38 PM
Feb-18-2016 01:36 PM
Feb-18-2016 12:24 PM
Ranger Smith wrote:
It is NOT supposed to light up. It will only come on if it does NOT ignite on propane. To check on propane turn off the electric heater for a day and then turn on propane only and it should ignite.
Feb-18-2016 11:38 AM
