water pump replacement
dtrink
I am looking to replace the fresh water pump on my 37' Class A. I was thinking about the Shurflo Extreme 5.7, but I have heard they have been discontinued and that they had reliability problems. I am looking for a high flow and pressure pump. Does anybody have any personal experiences of what would be a good pump?
8 REPLIES 8
Dutch_12078
I don't see much need for a high flow pump when the faucets are limited to 2.2 GPM at 60 PSI by law in the US.
Dutch
2001 GBM Landau 34' Class A
SCVJeff
ScottG wrote:
The 5.7 had many problems for lots of people but mine has been working great for ten years. It is an absolutely stellar performer - very quiet and strong. It has no problems with surge and it runs very slow and smooth under low flow conditions.
I honestly don't know that I'd recommend it though based on all the failures. OTOH, Shure Flow was always good about replacing them for the folks that did have issues.
Mine was replaced by the factory 2 years ago with a -4048 (IIRC) and I hated it. It turned into a backup for the Flojet. I dont think they are servicing the 5.7's at all
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
DSDP_Don
They're more expensive, but the FloJet VSD is a variable speed pump with good pressure.
FloJet
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
ScottG
SCVJeff
Unless something has changed, the Sureflo 5.7 was discontinued because of the massive problems it had. Be very careful about buying one, it might be a leftover.
Jeff - WA6EQU
enblethen
I have not seen the variable pumps recently. I did not find them at Shurflo website.
This would be a good replacement.
Shurflo 4048
Remco offers a variable speed.
Remco
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Dick_B
Be careful about buying a pump that has TOO high a flow rate because it will always be running at low capacity and may surge ie. produce a fluctuating flow.
We have the Shurflo 4.0 variable speed pump and it has been working perfectly for several years.
After checking the Shurflo website it looks like the variable speed pumps have gone the way of the buggy whips being replaced by a single speed pump with a bypass arrangement that produces a single output pressure by bypassing the flow that is not needed.
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
Ivylog
Some good info in this recent post
Upgraded with a 08 HR Navigator 45’...
