What Brand Of Keyless Entry Door Lock Do I Need
timmac
Wanting to upgrade my Trimmark 030-0900 lock to a keyless entry type, what brand and model do I need, anyone do this and is there a model for my Bounder.
:C
10 REPLIES 10
tderonne
"adaptable to power door lock actuation" just means there's a lever with a hole in it to hook an actuator to.
You can see the lever on the right:
Tim
2004 Winnebago Adventurer 31Y
Ford chassis
CharlesinGA
Visually, that is the same door lock that I have in my View, it has and electric actuator controlled by the vehicles locking system. Some recent View/Navion models had problems because the lock draws too much current and was burning up the Sprinter control module, so WBO modified the system by adding a relay and controlling the relay with the vehicles locking system and allowing the relay, fused separately, to operate the lock.
Yes, you need a spring loaded double contact set in the door jam, to transfer the power from the door to the jam. However it all works well.
Trimark also markets their own keyless system and fob, called e-ASK
http://www.trimarkcorp.com/en/zPlatFormList.aspx?intcategoryid=89&topcategoryid=175&scategoryid=176
You have this one here...............
http://www.trimarkcorp.com/en/zPlatform.aspx?platformid=22&categoryid=89
Note that it is "adaptable to power door lock actuation".
Charles
'03 Ram 2500 CTD, 5.9HO six speed, PacBrake Exh Brake, std cab, long bed, Leer top and 2008 Bigfoot 25B21RB.. previously (both gone) 2008 Thor/Dutchman Freedom Spirit 180 & 2007 Winnebago View 23H Motorhome.
Nutinelse2do
According to RV Lock, they are coming out with a lock for Class A's in 2017-2018.
Living Our Dream
MTHRSHP - 2006 KSDP 3912
Cummins 350ISL...Spartan Chassis
ESC POD - 2019 Ford Ranger XLT FX4
Zippy Scoot- 2018 Honda PCX 150 on an Overbilt Lift
Shredder at the Rainbow Bridge - You Will Always Be With Us
timmac
dougrainer wrote:
The aftermarket installs are the smaller door locks. You have the large Tri Mark and I have not seen a kit to replace your size lock. Doug
Thanks I have search the net and also have not found one, sure hope soon they start making one.
dougrainer
theczar
It is not needed nor was it difficult. I just replaced the lock on my 5ver. It took all of 10 mins. It has a keypad, remote and key as a backup. I love it. One thing I like about the one I got is the key is not the standard RV key that everyone has a master of. Looking on their website, it says they have a version coming soon for class A's. You might want to call them to get more info on what is soon. The website is: RV Lock
I have heard good things about Bauer for keyless locks as well. Their website is: Bauer Products
Hope this helps
timmac
usersmanual wrote:
its very involved as U need wires up door post and contacts installed and switch in the door(contacts) and a electric actuator installed etc if its like a factory deal
I saw one here at Vegas trailer supply that takes batteries and has a key backup but it did not fit my lock size, surly there is one out there.
usersmanual
usersmanual
frankdamp wrote:
Why? Keyless entry is just something else electrical/electronic to go wrong. If it uses a mechanical key as a backup, as my Kia Sedona does, you can still gain entry, but I wouldn't go "keyless" altogether.
no one goes keyless they all have a key as a back up
frankdamp
Frank Damp, DW - Eileen, pet - female Labrador (10 yrs old), location Anacortes, WA, retired RVers (since Dec 2014)
