Sep-26-2016 10:53 AM
Mar-16-2017 05:34 PM
Mar-16-2017 05:25 PM
Bruce Brown wrote:
They had a bulletin to do some of them...
Winnie Eternabond Fix
Mar-16-2017 06:25 AM
Jim Norman wrote:
Maintenance is one thing, have brake linings checked, get the oil changes, inspect your tires, check the belts. Climbing a ladder and recaulking a roof seam that probably should not need to be recaulked ever is a world of difference. My opinion is that if your roof needs to be checked that often and potentially needs that kind of maintenance you have a poor design. Some have said that they fixed theirs with Eternabond Tape, if it is that easy, then Winnebago should just put the freaking tape on the seam!
Mar-16-2017 06:05 AM
mike brez wrote:Bruce Brown wrote:
Wow, hit a nerve there? It wasn't me who posted their group had a 10 percent failure of there Winnie roofs, it was President of a Winnie club.
And BTW, my roof isn't rubber. My TT has a rubber roof, but it's not 10 years old yet.
If you'd like to come over and check out our roof for yourself come on over. I'll set you up with a place to park and hook ups. Heck I'll even buy dinner.
I'll come over and check it out. :B
Mar-16-2017 03:53 AM
fenwickfam wrote:I personally have no experience, but there is a member who used RV FlexArmor for his MH and raves about it. I have looked into both, and I'd choose this one over RV Armour. They actually remove all rooftop equipment while RV Armour does not. They also apply in a controlled environment while RV Armour does not. Good luck, and let everyone know what happens.jhilley wrote:
I am president of the WIT North Dakota Club. We have had three members out of our average of 30 members have this problem, one had it happen twice. It was repaired by the insurance company in all cases. In one instance, the whole roof was replaced. I think in all cases the work was performed by Leisureland in St Cloud, MN. In all of them after repair you couldn't tell it had ever happened.
It would be interesting to know what insurance providers they had... we have since changed to National General through Good Sam, however, and understandably so, our roof will not be covered should anything happen to it unless we have documented proof that it was repaired. This was a part of our decision to go with having RV Armour do the roof as it is covered with a lifetime warranty.
I'm curious as to if anybody has done the RV Armour on this thread and any pros or cons that you may have. I've also seen rvroof.com with a 'flex roof' as well as the linex roof.
Mar-16-2017 03:31 AM
Mar-15-2017 07:12 PM
Mar-15-2017 05:23 PM
tropical36 wrote:fenwickfam wrote:
We did point this out to the insurance company and to the ND Insurance Commissioner. They had told us to contact an attorney. Sadly, an attorney would most likely run as much as the cost for the RV Armour roof and take more time to get the roof fixed. As it is, we can't travel any great distance with it, so it needs fixed sooner rather than later.
Again you need an attorney. One letter from them, is all it's gonna take, if you're lucky. That won't cost much and if you choose the right firm, then they'll sue for all kinds of hardship and their charges as well and like the ones, I mentioned, there is no cost to you if they lose.
Mar-15-2017 05:12 PM
Bruce Brown wrote:There you go Bruce - banging your friggen drum again. You couldn't give me your POS rubber roof. I'm happy it has held up for you, because most never make it the 10 years. Buddy just showed pictures of his last week on another forum and his 3 year old rubber roof is totalled and the manufacturer gave him the same finger because they said he didn't follow the maintenance and inspection schedule. He sucked it up and had it sprayed.Mile High wrote:crasster wrote:rgatijnet1 wrote:
Unfortunately the maintenance on the roof is mentioned in your owner's manual. It mentions that it needs to be inspected regularly to maintain the seal.
For this reason your insurance company can back out just like they would if you let the oil go low on your engine.
This was a known issue and I'm sure that it is not the first time that the insurance company has dealt with, and rejected, paying for repairs caused by lack of maintenance.
Naturally the insurance company will claim that any receptionist(you did not speak to an adjuster) is not authorized to tell you what you can or cannot do.
This is a Winnebago design fault and let the buyer beware because even if YOU, as an owner, perform maintenance checks on a regular basis, like many do, they still may deny any warranty issues unless you have written documentation that the service was performed according to their standards.
I agree. Who thinks that gluing down a roof is maintenance? "Hey everybody... you .... you retired person..... Climb up that ladder risking life and limb often and make sure our glue didn't fail".
Crazy.
Usually Winnie is very good about stuff. This one surprises me.
Ah, so maintenance should be limited to only what a retired person can do :)? I guess I shouldn't be expected to change my oil or check my brakes either because I have bad knees (which I don't) - or did it possibly mean that you should do it or have someone do it if you aren't capable.
I think the point was more that it has to be done every 6 months, and it's not something you can do without either climbing up a ladder or working off the roof.
Plus the 6 month thing; I was just thinking about our roof. Ours will be 10 years old in August. I have spent maybe a total of maybe 10 minutes on roof maintenance, and it still looks like new.
Mar-15-2017 03:57 PM
Mar-15-2017 03:49 PM
Crazy.
Mar-15-2017 03:24 PM
Mar-15-2017 03:22 PM
Crazy.
Mar-15-2017 02:10 PM
Mar-15-2017 06:56 AM
