โJan-31-2014 04:24 PM
โFeb-01-2014 09:28 AM
MNtundraRet wrote:I don't have a problem and was not looking for help. I simply gave my opinion that the device mentioned was not worth wasting the money on. If you read all the posts you will see another poster agreed.
AZ99:
Judging from your dislike for the Sensor Pro, I would suggest you have other problems from just using the unit.
How far are you from the stations you are trying to get? Are there any mountains, or hills over 500 feet in your path?
Also; it looks like you did your own installation of your current set-up. You most likely have a loose connector, or cable pulling loose from the connector. I would check all connections on the back of the plate, plus those going to the TV. If you go through the switch-box (BOMB) I would run the coaxial directly to the TV to rule out bad connections from the BOMB.
Make sure you disconnect and clean the coaxial connection to the antenna on the roof. This is the most likely place for wrecking incoming signals.
By the way. By complaining about your equipment you are the only one suffering about lack of stations. The rest of us would like to help but we could care less if you refuse to accept help and put the blame where it really belongs.
โFeb-01-2014 09:22 AM
โFeb-01-2014 09:19 AM
RLS7201 wrote:I know how to then rotate the antenna 90ยบ and scan and fine tune 3 more times to cover all areas. The instructions tell you to scan with your TV where the most channels were. But without knowing which channels are where you may still not have been aimed in the direction you really want to be. You still need to know at least 1 of the channels that is in the direction you are shooting for.
You make a good point about finding the strongest channel. Now go back and read the instructions and learn how to force the Sensar Pro to othere channels so you can see where they're at. It's not as worthless as you think. It does require some effort on your part.
Richard
โFeb-01-2014 09:04 AM
โFeb-01-2014 09:03 AM
โFeb-01-2014 08:49 AM
az99 wrote:
You still need to know the channels. The thing will tell you the strongest channel is 32 for example aiming north. That is great but 32 happens to be 1 local spanish channel and then you let your TV scan for 30 minutes and find out you have 1 worthless channel. In this example all the network channels were to the SW. So either guess again or get out the laptop.
So unless I knew to set the Sensar to channel 17 for example and rotate the antenna until I get the best signal on 17 using the strongest signal was worthless. I still have to go to a site like antenna web and see what channels are available and it shows me what direction they are in.
Like I said the Sensar is worthless unless you know the channels or get lucky and have the channels you want where the scan points you.
โFeb-01-2014 08:34 AM
โFeb-01-2014 07:39 AM
โFeb-01-2014 06:19 AM
az99 wrote:Johno02 wrote:Don't waste your money. It is called the SensarPro. It doesn't improve signal and just complicates aiming the antenna. If I hadn't cut a hole in the wall to mount it, I would throw it away. You need to first know all the real channel #'s of what is available in the area to make it useful.
Winegard makes a new control panel which helps aim the antenna, and may boost reception a bit.
โFeb-01-2014 06:10 AM
โFeb-01-2014 06:08 AM
โFeb-01-2014 03:54 AM
โJan-31-2014 09:44 PM
โJan-31-2014 05:27 PM
โJan-31-2014 05:22 PM
Bill.Satellite wrote:
Do a search here for Batwing vs jack antenna. Your Batwing with an added Wingman attachment is a superior performing antenna. Being able to raise the antenna above the surrounding obstructions also make it perform substantially better.
