Can someone answer a questions about a class C?
Hanniball666
Is there anyone online now that can answer a question concerning a class C?
32 REPLIES 32
wa8yxm
IF the unit filled with propane.. The first thing to check is the knobs on the stove and oven.. Had a woman in the park where I winter looking for a technician to fix a propane leak in her rig.. I offered to take a look, (When it comes to propane I can look but I won't touch)
The stove knobs OFF OFF *on* OFF
That one was easy to fix.
If that is not the problem. Have a professional look at it.
mlts22
Only reservation about that is if the master gas valve at the tank is faulty, there may still be a gas leak. Not to say this is common, but better safe than sorry.
I'd almost say to haul it back to a dealer so they can do a complete stem-to-stern check of the propane system and appliances for safety's sake.
rexlion
2012Coleman wrote:
rovinredneck wrote:
a portable space heater should work, leaving all the lower cabinet doors open...what kind of temps are you expecting tonight?
Since the OP reports leaking gas and alarms, I'm not sure the right advice at this time is to use a portable heater..
If the gas is turned off at the tank, running an electric heater is as safe as can be.
Mike G.
Liberty is meaningless where the right to utter one's thoughts and opinions has ceased to exist. That, of all rights, is the dread of tyrants. --Frederick Douglass
photo: Yosemite Valley view from Taft Point
rovinredneck
I know everyone wants to help, and any advice given is in good faith. I hope that the OP will get back to us with the solution to his problem. Unfortunately some posts get out of sequence and the response can be confusing..but I'm learning.
scroller95969
With a name like Haniball666 I would be very careful with anything that could produce fire:E Sorry I just couldn't resist.
Jeff & Lori
2004 Fleetwood Tioga 22B - Chevy chassis
10' Wells cargo trailer
Gracie Mae - our 9 year old Papillon
2012Coleman
Experience without good judgment is worthless; good judgment without experience is still good judgment!
2018 RAM 3500 Big Horn CTD
2018 Grand Design Reflection 303RLS
ronfisherman
Moderator
Moderator
Could one of the burners on stove be on?
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
2gypsies1
You said you brought it home to winterize it. Therefore, you must have used the furnace previously at one time. Any problems then?
If you had that much propane coming into the RV to set off alarms, you definitely have a problem. Best to get it checked out, for sure, and make sure it's totally aired out.
Full-Timed for 16 Years
.... Back in S&B Again
Traveled 8 yr in a 40' 2004 Newmar Dutch Star Motorhome
& 8 yr in a 33' Travel Supreme 5th Wheel
wbwood
I say take in it to the shop tomorrow and have them check the RV for leaks and let them winterize it for you while they are at it. Not getting that fixed will only cause problems. You never used the propane at all before? Not even to heat water or use the stove?
Brian
2013 Thor Chateau 31L
bikendan
if it's a new rig and you didn't burn off the oils in the furnace first, that will set off the alarms.
dealer should have advised you of this during the PDI.
Dan- Firefighter, Retired:C, Shawn- Musician/Entrepreneur:W, Zoe- Faithful Golden Retriever(RIP:(), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
othertonka
If the RV filled with propane, you have a leak or a broken propane line somewhere. Turn the propane off and air the rv out until you get it fixed. After it is aired out, use a stand alone electric heater set on low with all the cupboard doors open to keep the water pipes and drains from freezing. Get that propane fixed before you have an accident.
Othertonka
2004 Southwind 32VS 8.1 Workhorse chassis
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
Old-Biscuit
Furnace combustion air mixes with the propane for flame and then exhausts OUTSIDE the rv...........unless you have a cracked/bust combustion chamber no propane will come inside rv.
Check the stove top burners......make sure the knobs are turned OFF
Hanniball666
Tried it one more time. Turned on the gas, burner came on with hot air coming out, alarm went off and wouldn't go off. No smoke, just the smell of gas. Turned everything off, aiared it out and will leave it for the night. Thanks for all of the suggestions. Much appreciated and I didn't get blown up. Nothing wrong with that I guess.
rovinredneck
I think you've been given great advice, Hannibal...relax, get some sleep and we'll fix it in the morning. good night from the redneck in Alabama
