Jun-12-2015 08:31 AM
Jun-14-2015 01:16 PM
wbwood wrote:This is the best advice for dumping at a dump station.
It's not a race. Dump and clean your tanks to your liking. Be mindful if you have traffic behind you waiting.
Jun-14-2015 12:34 PM
Jun-14-2015 12:20 PM
Jun-14-2015 07:47 AM
GaryWT wrote:It is tough... my legs get stiff and achy.bcarroll wrote:GaryWT wrote:To put your mind at ease(hopefully), I disconnect the dump hose and hold it under the dump valve. The sprayer I use is a hand held attachment where you squeeze the handle and it squirts a stream of water up into the dump valve pipe/tank - I do not put the hose up the dump valve pipe. Rinsing the dump tank is the only purpose for that.
What has me concerned about what the OP said, hopefully I read it wrong, after dumping he disconnects the sewer hose and continues to flush for an hour. Where does the water go. At first I thought he was rinsing the were hose with a water hose but the said he does his tank. This stuff cannot go on the ground. I also cringe when I see people stick a hose into the sewer hose, now that hose I'd gross and unusable for anything.
All the water etc. drains into the stinky slinky - none on the ground.I have never timed it but I dump the black, go inside an stand on the peddle for a couple minutes and then totally fill the bowl 2-3 times to flush a rush of water. Go outside an close the black nod open the gray. While that is happening I go in, add water to the black tank and add the aqua chem. go out, close the gray, put the sewer hose away and wash up. This is all done at the site as we only go to full hookup sites, have never used a dump station.This is the reason I ask - there has got to be a better way than I am doing it, and I may not need to worry about as much if it is not a problem.
Plus, I only take this long at full hook-up camp site, not a dump station.
My concern is how much is left in the tank after a quick dump.
That sound tough to stand there with sewer hose in one had and hose in other spraying into the tank while you try to catch the water coming out. As someone else mentioned there is a fixture you can use to connect the hose to so it is a closed system. Also they make something that you can stick in the toilet itself. Have never needed either but they are out there.
Jun-14-2015 04:12 AM
Sport45 wrote:spoon059 wrote:
Just a wise observation that my father has told me in the past... a wise man speaks because he has something to say. A fool speaks because he has to say something.
So you had to say something...
Oops!, looks like I did too. 🙂
campigloo wrote:
Boy spoon, you're really wound tight. Maybe you should think about just staying home and yelling at your kids instead of taking out your stress on everyone that does something not according to your standards.
campigloo wrote:
Apology graciously accepted
campigloo wrote:
Oh really spoon? You think screaming at people and calling them names is a class act? Maybe you need to read your own post about being polite and friendly. I'm one of those "whiteheads" you so adore and I take offense at the comment. What did your father say about hotheads?
campigloo wrote:
Spoon, this has gotten waaaay out of hand. I'm just asking you to relax a bit. There is no written in stone ways to do anything. I do things that annoy others. It's not intentional. You do things that annoy others, and I would like to think its not intentional on your part either. You're just not the only one that has to deal with stress. Most of us whiteheads have already dealt with screaming kids and work schedules, so we know where you're coming from. Just try to realize we're all just trying to enjoy our limited time on this planet and doing the best we can.
Peace? Brother?
Jun-13-2015 08:11 PM
Jun-13-2015 07:59 PM
Jun-13-2015 07:58 PM
bcarroll wrote:kohai wrote:I don't have one of those "spinner things"... what is that?
I'm slow too.
My process:
- Hook up black tank flush hose and turn on (that spinner thing).
- empty black tank
- close black tank, fill it again through the black tank.
- empty black tank while monitoring clear elbow
- If I still see toilet paper or anything, I repeat again (or if going into storage for month) otherwise done.
- then I empty the grey tanks
- add some water into the black tank, put digest packet into toilet/tank
- add some water to grey tanks, put some deodorizer down sinks
This was based on a video I watched.
If the hose I use to fill the black tank back up is slow, I'm slow. I'm guessing I'm 20 minutes to get this done on a good day.
I don't have a clear elbow either, so I improvise. Been thinking lately that it would be a good idea to get one.
I normally put the deodorizer/digester pack in the tank when I first set up camp - is it a post dump process?
Jun-13-2015 07:57 PM
Jun-13-2015 07:27 PM
Jun-13-2015 01:09 PM
Jun-13-2015 10:32 AM
Jun-12-2015 07:26 PM
