How do I haul water to my camper ?
Happy_Camper3
I just got my camper placed on my land. It's too far for any local water ..
I plan on leaving the camper there all year
Am I suppose to haul twelve 5 gallon jugs of water up there every weekend ?
what does everyone else do ? I plan on having a well put in after a few years
27 REPLIES 27
mbopp
Grit dog wrote:
Couple 55 gal barrels in the back of the pickup and a hand pump or little puddle sucker to transfer.
If you're lucky you can get them to siphon feed into the trailer water tank.
2019 F250 XLT Supercab
Just DW & me......
riven1950
Don't know if this is practical in your area, but if you have sufficient rainfall during the summer you could collect rainwater, especially if you happen to have an outbuilding etc in addition to the rv to increase surface area for collection. Could be filtered some and used except for drinking. Many similar systems in use in Mexico / Central America / Islands where water systems are not reliable. Of course you must have enough rainfall / collection ability to justify the system. Just trying to think of something no one else mentioned.
RinconVTR
nitrohorse wrote:
Use Reverse Osmosis. You can recoup the water from your grey and black tanks.
That will save you the amount of water you must haul.
Cool idea, but not practical. This would require 2-3 prefilters ahead of the RO filters, which I dont think you would want to ever change without a gas mask and rubber gloves! And, the sheer number of prefilters required would be a $$$ shocker.
You also need contant line pressure to run the RO, meaning your trailer pump would be cycling all the time as water is filter and it filled the small stoarge expansion tank.
Worst of all, many solids would remain in the tanks and slowly harden at the bottom, much like a septic tank, if they are never drained/flushed.
Sorry for the long winded take down, but I wanted to squash this before someone really spends money to try it!
RoyB
The tank can be almost anything in the back of your truck. A empty 30 GALLON BLUE TOTE with wheels doesn't weigh hardly anything.
You can carry this is the truck bed real easy and use any number of 12VDC PUMPs to transfer the water... No big effort on your part at all...
Then get another one those TOTE tanks (different color or PAINT it RED to know which is waste water) and use it to haul off all of your waste water. Just be sure the tote is bigger that the tank you are emptying so you don't over fill it and mess up the back of the truck bed...
The Flojet 18555-000 Waste Water Pump is a great waste water kit that will connect to your trailer waste valve and transfer to the tank in the back of the truck...
Don't get caught pumping waste water on the ground... Not worth the fine...
Just my thoughts
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
skipnchar
There are basically only three ways to get water into your RV. The EASIEST is to hook up to an existing water source but doesn't sound like that's possible in your case. The NEXT easiest method is to take your RV to the nearest water source and fill it. One of the beauties of RVs being so portable. The last and least favored is to carry water to your RV for use on the site. You can use about any METHOD of carrying it you like. Probably the lowest cost is to purchase 6 gallon plastic jubs (Wallmart at a cost of around $7.00 each) and the MOST costly would be to purchase an appropriately sized water tank for the back of a truck. YOu lcan siphon it (almost free) or add a water pump like the one in your RV for a modest investment in the pump and somewhat larger one in the tank.
I ALMOST always use a combination of taking the RV to the water source plus carrying more water than the RV can cold (6 gallon jugs) but I let the exact method depend on the situation.
Good luck / Skip
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
nitrohorse
Jack_Diane_Free
I have a 25 gal water tank that I put in the back of pickup. Fill with water and use 12v transfer pump.
liquidspaceman
Unless you have a Magic Water Machine, anything you do is going to require either the manual labor of transferring the water by hand and/or using large barrels/containers plus some kind of truck/atv/etc to haul it in.
The only other option would be some kind of pump and piping leading from water source directly to you or a well.
This is the reason why remote locations are not popular real estate because it takes hard work or lots of money to get water in easily.
firemedic08
We have a Friend who Uses a Totewith lid From Walmart, that he Plumbed a 12 Volt Pump into and uses that to fill his. He has had a permenant Lot for years and still uses this method instead of drilling a well. Works great.
Donnie
1994 Chevy 2500 Extended cab
1987 28 ft travel villa 5th wheel.
thirtydaZe
take this opportunity to get a nice atv and tank trailer. :thumbsup:
2019 Jayco Eagle HT 324BHTS
2024 Ram 2500 68RFE
Grit_dog
Navigator
Navigator
Bionic_Man
I have one from High Country plastics for when I boondock. I used a spare water pump to transfer. Works great.
High Plains
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
2oldman
Only if you want to do it as cheaply as possible and work your buns off. I had custom tanks made at watertanks.com
Water tanks in bed
