โOct-23-2016 11:25 AM
โOct-24-2016 06:18 AM
EnzoColorado wrote:
The dealer said the 20BHLE will tow better, sway less and bounce less due to the tandem axles.
โOct-23-2016 08:23 PM
โOct-23-2016 03:21 PM
โOct-23-2016 03:14 PM
โOct-23-2016 02:01 PM
EnzoColorado wrote:Haakon wrote:EnzoColorado wrote:Grit dog wrote:
You're correct in that those are the only discernible differences.
Yes replacing BOTH gearsets is expensive and not worth it IMO.
Trans cooler, limit how hard you push er up the hills and all the other stuff you're planning, a 5klb trailer will be fine. Just won't be the first to the top of the pass with that kind of load at altitude.
Thanks! Racing to the top of Independent Pass is not a priority even without towing a trailer.
While reading this forum, I found a link to a VIN decoder and found this particular bit of spec for my VIN:
Dead Weight Hitch - Max Trailer Wt. 5000 lbs 5000.0 min 5000.0 max
Dead Weight Hitch - Max Tongue Wt. 500 lbs 500.0 min 500.0 max
Wt Distributing Hitch - Max Trailer Wt. 8000, 5500 lbs 5500.0 min 8000.0 max
Wt Distributing Hitch - Max Tongue Wt. 1200, 825 lbs 825.0 min 1200.0 max
So if I use a WD hitch as I planned to, my max trailer weight will go up to 8000 lbs? So really no issues then.
No, that's what the hitch is rated for not your vehicle. They use the same hitch on most if not all of the half ton Suburbans. Regardless of the hitch you still don't have the tranny cooler and have 3.08 gears.
Okay, got it. Still plan to install a HD tranny cooler.
โOct-23-2016 01:54 PM
โOct-23-2016 01:52 PM
โOct-23-2016 01:40 PM
LadyRVer wrote:
IMHO, if the tandem axle is within your weights, I would choose that one. My reasoning is better safety if you have a blowout.
Recently I had two tire failures same trip. One each side. Tandem helped me out.
โOct-23-2016 12:35 PM
โOct-23-2016 11:58 AM
APT wrote:
Here are the tow ratings for your year Suburban:
3.08 - 5300 pounds
3.42 - 5800 pounds
3.42 w/ HD trailering Equipment (HD Trans cooler) - ~8000 pounds
The trans cooler make more of a difference than the gearing. I recommend a high capacity trans cooler if you plan to tow any high walled RV. If you install that, then you should be fine for up to about 5k pounds dry. The 6-spd with 3.08 gearing is actually better than the prior 4-spd trans with 4.10 axle. Use tow/haul mode, limit the trans gear to 4th max (M4), and keep the engine over 2000rpm, 2500rpm better.
โOct-23-2016 11:55 AM
โOct-23-2016 11:54 AM
โOct-23-2016 11:34 AM
