water filters
donandmax
We have an under sink water filter. These things cost about fifty bucks for just the canister. You can't completely empty them. We use our moho for about 3-4 weeks out of the year. Cant we somehow use these again instead of throwing 50 bucks away and buying new ones just to use for a couple of weeks. Thats awful expensive filtered water. Besides with the exception of taste which is bad in some states we're not sure filtering campground water is all that necessary.We've been using rv parks( only) for several years and never caught anything from drinking their water. After all the owners drink it too.But it does help with the taste.
I've heard you can freeze them so nothing bad starts growing in them. Just thought I would ask your opinions on reusing.
If it aint broke fix it till it is
12 REPLIES 12
donandmax
My original question was concerning canister type filters in which the filter and canister are all one unit.And it is impossible to drain all the water out of them. Yes they are good for one year. but you can't let the old water just sit in them and think they are good to go a few months down the road and continue to use them until that year is up. I realize there are filters that you hook up on the end of your hose and yes they can be changed out rather cheaply. But canister types are 50 to 60 bucks a pop.And to buy a new one for a 2 week vacation is just ludicrous. So I think putting them in the freezer might be the answer. How many do that ?
Jim-Linda
It really depends on what you want to filter. You can remove particles, chlorine, bacteria, etc. After you do the particles, the rest is more expensive. We have an undersink EverPur that handles chlorine and some particles. The elements are $38 from efilters.com. The element as used needs replacing yearly. We also have a whole house outside filter from HD that will use either a particle or carbon element. This is changed every 6 months. Good water.
Jim
RJCorazza
I don't use mine more than one season, but to reduce costs I made up a whole house filter that uses standard (relatively inexpensive) filters. There are a wide range of filter types available anywhere.
Dennis_M_M
We just use a Britta water pitcher for our drinking water. We keep two Rubbermaid containers in the fridge with drinking water, fill one, fill the Britta pitcher and when the next Rubbermaid is empty the Britta is full of filtered water.
'99 Volvo VNL610 - 425 HP Volvo; Super 10 Spd
'13 smart CityFlame on Volvo
'05 Newmar Mountain Aire 35 BLKS
Trailer Saver; Bigfoot; Pressure-Pro.
Our Travel Blog - A New Adventure
dodge_guy
I have a 10,000 gallon "whole house" water filter in mine. it was an option. I only get the filter for it when I`m going to be using the fresh water tank. I also have an undersink drinking water filter with dedicated faucet. I use the same filter all year long. I too use it about 3-4 weeks a year. no issues!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
Johno02
I use a cartridge filter in the fresh water line to the coach. It just sits in the bin next to the city water inlet. Connected with snap fittings so its is easy to insert in the line or remove and drain for storage. Wintertime, just remove it from line, drain and store till next year. Replace cartridge as needed.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
handye9
ScottG wrote:
I noticed some time back that they started using some odd sized filters that are silly expensive.
For that kind of money you could buy a new housing (I think I paid <$30) and get a twin pack of filters for $10 and be money ahead after that.
Swapping the housing, would pay for itself, with the first cartridge.
You could also do what I did. I put a bi-pass around the filter housing and drink bottled water. Besides saving on cartridges, it saves antifreeze, when I winterize.
If I want to use the filter, just install a cartridge, and turn a couple valves.
18 Nissan Titan XD
12 Flagstaff 831FKBSS
Wife and I
Retired Navy Master Chief (retired since 1995)
coolbreeze01
I quit using the filters and don't miss them.
2014 Sandsport 26FBSL
travelzoo
Our filter goes to a drinking water only faucet. I remove the filter, empty the water as best I can. Place in a plastic bag and freeze. When I notice a decrease in water flow at the faucet I change filters. It's worked fine for us for many years.
Pangaea_Ron
I've read here somewhere on the forum about draining the filter putting it in a Zip-loc bag and then freezing it to use again? I'm not sure about possible damage?
Here is a similar thread.
2008 Itasca SunCruiser 35L
2014 Honda AWD CR-V EX-L
donn0128
Mine are a standard filter commonly found in big box stores. Complete filter assemblies are pretty reasonable, and easy to exchange for what you have
ScottG
