Jun-01-2014 02:36 AM
Jul-26-2014 12:35 PM
4wlow wrote:spud1957 wrote:4wlow wrote:
I could get close if I could find a way to lower the front since I have around 11 inches of clearance between the top of the bed and the bottom of the 5th
What is the lippert alignment kit
11"? 6-7" is enough. Between your hitch and your trlr pin you could decrease that down to an acceptable height.
That is my problem both are maxed out to provide the lowest position. Lowest position on the hitch can not be used due to the slider platform. highest position on the pin box is limited that the pin box would hit the bottom of the 5th wheel cap. before the top holes are lined up. Right now my options are limited by the Ram factory 5th wheel prep package. I looked at the B&W hitch for the Ram prep package, but that would only lower the front by slightly less than an inch. I plan on weighing my axles. how much of a weight difference between the two is too much.
Jul-25-2014 08:52 AM
Jul-25-2014 07:21 AM
Jul-25-2014 07:00 AM
Jul-24-2014 02:22 PM
Jun-09-2014 06:56 PM
4wlow wrote:
I have a 20k reese select slider on top of the picture frame and a trail air pin box. I like the pin box, but maybe I could get one with a lower profile. I was also looking at maybe getting 17.5 wheels and tires. I would gain a little height and higher weight rating on the tires. That is expensive though$2000 plus. I do have Chinese tires now.
Moderator edit to re-size picture to forum limit of 640px maximum width.
Jun-09-2014 11:38 AM
Jun-09-2014 11:07 AM
Jun-09-2014 09:27 AM
Jun-09-2014 05:39 AM
Jun-09-2014 04:48 AM
Jun-08-2014 06:48 PM
RCMAN46 wrote:
To OP
You state you have 11 inches from bedrail to trailer. I am almost sure your bedrail is about 60 inches from the ground. Add 11 inches and that gives you 71 inches. 5 11. I am 5 9 so I could walk under your trailer when hitched?
How about some pictures of the pin box and trailer hitch.
A picture when hitched would be helpful too.
Jun-08-2014 05:42 PM
Jun-08-2014 03:13 PM
Jun-08-2014 12:58 PM
