Air conditioner wasps
tbr2015
I can’t find anything in the search about this. Has anyone come up with a solution to keep wasps or yellow jackets out of the air conditioner? I found a large nest in mine. I’m thinking about zip tying window screen on the inside of the cover, but don’t want to hinder air flow too much.
4 REPLIES 4
2oldman
You tube.. your problem
Grit_dog
Navigator
Navigator
Toss a chunk of meat up there and hit em with Raid when they are having a meal.
Drive 80mph of 80 miles.
Uhh, just kill em and remove the nest.
Fisherman
If you can find the screening they use to make the ones to cover fridge vents and furnace vents, that would be the answer.
TurnThePage
I have intended to do something similar for a long time. I would use something with just a little larger holes, and probably not the typical nylon netting that screens are made of. I also considered removing every other vertical slats to open up more room for air flow.
2015 Ram 1500
2022 Grand Design Imagine XLS 22RBE
