Brake systems for dinghy
Jayco-noslide
I currently don't have brakes on our toad Chevy Sonic (2700 lbs) but I will be replacing it, possibly with a Ford Focus (3000 lbs) and will want a braking system. I want the least troublesome, least intrusive and one I don't have to put anything on and off when going from towing to not towing. You get the idea. I won't say price is irrelevant but it's not the main factor. Opinions appreciated.
Jayco-noslide
11 REPLIES 11
avan
Blue Ox Auto Stop can also be purchased independent of the tow bar in the event one already has the tow bar. And if you live in IL and want a factory install of a base place and the auto stop cable to the brake pedal, BO in Pender, NB is not that far away. Great free campground for you as well.
www.putt10.net
cooper841
Easy ready brake.
Dana Cooper
Chipper(Lab)
2007 Fleetwood Fiesta LX
2003 Harley Fatboy mighty hauler lift
2010 Kia Soul
loggenrock
X??? on NSA! About 15k miles using it - very dependable, less weight, no "box" to store, less $$$ (!). Simple, easy, effective! ST
Two and a hound in a 2015 Coachmen Prism "B+"...pushed by '09 Suby Forester
First 50 done, working on the second pass! Nunavut - we'll see...!
2005-2015 Roadtrek 190P
1993-2005 Northstar Soft-Side TC
1989-1993 Backpacks & Tents!
1967-1977 Family TT's
RedRollingRoadb
NSA ReadyBrute Elite. Worse part of installing the brake cable was getting under the car.
Dutch_12078
lanerd wrote:
mowermech wrote:
gbopp wrote:
Have you considered Readybrake?
If I ever buy a braking system for a towed motor vehicle, that is what I will get, there is no doubt in my military mind!
Since the OP already has a toad, I'm assuming he already has a tow bar. If that's the case, then getting a Readybrute Elite probably wouldn't be wise unless the tow bar is old and needs replacing.....then, I too, would go with the Readybrute.
Ron
NSA makes both a standalone ReadyBrake brake only unit and the combination ReadyBrute Elite tow bar and brake unit.
Dutch
2001 GBM Landau 34' Class A
lanerd
If he is going to keep his current tow bar, then I think I would go with the Roadmaster Invisabrake mentioned above. Once installed there is absolutely nothing to connect/disconnect....very similar to my US Gear Unified brake system.
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
Ava
I use the Roadmaster invisibrake. All parts are hidden. Check the different features of all these popular types to make a decision.
mowermech
CM1, USN (RET)
2017 Jayco TT
Daily Driver: '14 Subaru Outback
1998 Dodge QC LWB, Cummins, 5 speed, 4X2
2 Kawasaki Brute Force 750 ATVs.
Pride Raptor 3 wheeled off-road capable mobility scooter
"When seconds count, help is only minutes away!"
jplante4
We sell a few of these every season.
Jerry & Jeanne
1996 Safari Sahara 3530 - 'White Tiger'
CAT 3126/Allison 6 speed/Magnum Chassis
2014 Equinox AWD / Blue Ox
gbopp
Hank85713
We have the SMI kit on our towed hyundai. Works well and is unobtrusive. Controller is under hood on off switch on drivers kick panel. Just bought another from a friend for my ranger which we plan to tow when we need to take the grandkids fishing so we can load a boat on it. its a roadmaster invisbrake should be much like the smi unit. the hyundai is less than 3000lb, the ranger as it sits is about 4000.
