Charge Line
Daddy_Bear
I have a 2007 Chevy Silverado. Everything on my trailer plug works just fine except the "Charge Line". It is factory wired and worked last year. Does anyone know if theres a fuse anywhere on the truck that would kill the charge line if the fuse was blown?
Thanks
Drew, Lora & our two boys
Sophie our Toller
2016 Chevy CC, LTZ, LB, W/ Duramax & Allison, B&W Turnover ball and Companion fifth wheel hitch
2015 Grand Design Momentum 328m Toy Hauler
Renology 300W solar
Honda 2000i
8 REPLIES 8
OH48Lt
If it worked last year, then it has to be a relay or fuse. On Fords, they put these items in the glove compartment, and the new owner gets to install them. Check your owners manual and see what fuse and/or relay powers that line. I had to replace a relay on mine.
2017 Ford F-150 Crew Cab 4x4 3.5 EcoBoost
2014 Cruiser RV Fun Finder 215WKS
2015 Harley Road Glide Special in Amber Whiskey
2019 Mustang Bullitt
Yamaha Grizzly 660 (his)
Polaris Sportsman 500 H.O.(hers)
APT
Check your ownerrs manual. This might be it or if you have the NBS 2007.5, search for 2008 Silverado HD owners manual. Stud 1/location 70?
A & A parents of DD 2005, DS1 2007, DS2 2009
2011 Suburban 2500 6.0L 3.73 pulling 2011 Heartland North Trail 28BRS
2017 Subaru Outback 3.6R
2x 2023 Chevrolet Bolt EUV (Gray and Black Twins)
mkirsch
Nomad II
Nomad II
Yes, 40A. That's what GM has spec'd since 1999.
In the 99-06 trucks, you needed to install a fuse in the "Stud #1" position in the fuse panel under the hood.
Apparently in 2007-later trucks you also need to connect the line to Stud #1 in addition to adding the fuse.
Chuck_thehammer
my 2012 Ford F 250 has a 25 amp fuse for the trailer battery. aka charge line.
I know because I purchased the truck 2 months ago.. and was one of the first things I checked after connecting trailer to truck.
Lights, Brakes, Battery voltage.
WyoTraveler
40 amp? Wow! Probably won't hurt anything. I'm a Ford guy. Never ever measured more than 10 amps on my charge line. I would measure your charge current. Maybe allow more and fuse it. If it worked before probably not a dummy fuse.
The_Texan
First off, are you sure it worked fine last year?? Not being factious, but GM factory wired does NOT mean what you think. Their factory wired charge line means they ran the wire from the plug forward to the engine compartment, BUT did not connect it at the fuse box. This has been standard practice on the GM trucks for years. The line is setting under the fuse box in the engine compartment, on the drivers side. You must fish it out and hook it up, if you want to use the charge line. There will be a dummy fuse in the slot for the line and you will have to buy the correct 40A fuse to install, once the line is hooked.
My truck has the NHT package which is the HD Max towing package, but the charge line was not hooked up. The same was true with my 2005 GMC truck.
Bob & Betsy - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
2005 HR Endeavor 40PRQ, '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2017 Rzr 4-900 riding in 16+' enclosed trailer in back.
Where the wheels are stopped today
Chuck_thehammer
should be in the Main fuse box. look in owners manual
or its can be printed in the underside of fuse box top.
downtheroad
Under the hood - driver's side fuse box (toward the front near the fender...Probably a "dummy" in there now.
I think you need a 40a fuse. It goes in the stud labeled B+ ...Probably a "dummy" in there now.
disclaimer:
(I'm doing this all from memory which isn't all that great).
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
