Charging battery with tow vehicle
marquette
I didn't want to hijack the current thread on time e to charge a battery with the tow vehicle but I read of people changing the charging wire to a larger size to get better charging. For those that have done it how large of a wire size did you go to and how much effect did it have? I have a 2001 Suburban and know I have 12v to the center pin on the 7 pin but no idea beyond that of what I have.
14 REPLIES 14
howardwheeler
Five years ago or so I installed parallel 6 gauge wires, both positive and negative, with a solenoid controlled by one of my up fitter switches that goes to a plug in the bed, a plug like you see on winches. I then ran 6 gauge wires directly into my 4 125 amp hour batteries in my Alpenlite.I now arrive wherever I'm going with fully charged batteries. I have a residential frig so I run an inverter while traveling. Not only does the heavy duty alternator keep up with the inverter draw from the frig but it also fully charges the battery bank.
urbex
RoyB wrote:
The typical Truck Alternator setup was only typically designed to charge up the ONE Truck Start battery.
My understanding has always been that the alternator is there to maintain a state of charge, not recharge a low battery. This is an important distinction, as the alternator doesn't have the circuitry in it to properly charge a deeply discharged battery. Sure, driving around for a while will eventually "fill" the battery back up, but it doesn't do it in a way that maximises battery life.
The intentions of the high amp alternators, and dual alternator setups is for vehicles that have higher than normal electrical loads, such as emergency vehicles with a bunch of added lights. electric hydraulic pumps, bigger cooling fans, etc.
It's always been my understanding that the 12V charge line was intended for maintaining small batteries, such as those that power the breakaway system on trailers, not charging up the house battery (or batteries). Even then, you're supposed to charge the brake system battery to full with a battery charger, then the TV maintains that charge.
https://www.optimabatteries.com/en-us/experience/power-source/fact-alternators-are-not-designed-to-c...
1990 Ford F350 CCLB DRW 7.3 4x4
1990 Lance LC980 truck camper
marquette
How many watts to get 15amps in the morning?
westend
The thing about solar is that it doesn't take a break, it's there producing power if the sun is up. I live in MN and have my trailer parked (for the most part) during Winter. When in storage, the module is tilted so the snow falls off and I have a better angle for insolation. You would be surprised what a single panel can produce in a day, it is significant. If my batteries are discharged, I am usually seeing 15 amps of power in the morning. It doesn't take too long to get the batteries charged back up.
'03 F-250 4x4 CC
marquette
I'll have to check but my guess would be that I have a 135 amp alternator in a LT package with rear heat and A/C. I can't imagine on a 1/2 ton Suburban that dual batteries would have been an option so even a 160 amp alternator might not have been possible without an aftermarket upgrade. Sounds like take what amps I can get leaving the Suburban stock and plan on using the generator when I stop. My first thought was solar but I do a lot of September-November camping while hunting and I don't think solar will do much then in Minnesota and the Dakotas. Not enough high angle sun to justify the cost of solar.
GordonThree
beemerphile1 wrote:
RoyB wrote:
There may be a doubled edge sword here if you beef up the charge cable from your Truck Alternator system.
The typical Truck Alternator setup was only typically designed to charge up the ONE Truck Start battery. Each battery in a system when being hit with 14 PLUS DC charging voltages could demand as much as 17-20AMPS DC Current from the source. This could be more DC Current demand than the standard Truck Alternator setup can produce....
You are correct to an extent. One needs to know their vehicles capabilities. My new truck has a 220 amp alternator. I haven't looked yet to see what gauge wire they used in the factory tow package.
Getting two alternators was also an option.
I've been seeing the 220 as part of snow plow prep option on Ram 2500's as I window shop for my Outdoorman replacement... it had rekindled my thoughts of an auxiliary charge line to my trailer's battery bank.
beemerphile1
Build a life you don't need a vacation from.
2016 Silverado 3500HD DRW D/A 4x4
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
RoyB
The typical Truck Alternator setup was only typically designed to charge up the ONE Truck Start battery. Each battery in a system when being hit with 14 PLUS DC charging voltages could demand as much as 17-20AMPS DC Current from the source. This could be more DC Current demand than the standard Truck Alternator setup can produce. Using the standard #10 gauge wire back to the trailer connector most likely will compensate heavier load by having some voltage drop which in turn may protect the truck alternator better from too big of DC load providing less charge current of course.
Also some of the older trucks have this charge line always connected which may run down your truck start battery if left connected for a long period of time without the truck motor running. This is why the newer trucks have this charge line under ignition key ON only control...
Adding the smart relay to the truck alternator setup to only be connected when the truck alternator is in CHARGE MODE ONLY will in most cases be governed by the truck start battery being so close proximity to the Truck Alternator. The Trailer battery may be too far away distance wise to effect any charge mode changes to the truck alternator sensing setup. In other words the Truck Alternator will sense the Truck Start battery meet its charge mode state and then drop the smart relay back to its OFF state. The trailer battery would then stop being charged by the truck alternator and may not have met its charge state yet... It may take a longer time to get both batteries fully charged to their 90$ or 100% charge state so they can be used again...
The Trailer Rv Batteries can withstand a 50% charge state and can be recharged backup to their 90% charge state and be used again whereas a Truck Start battery can only withstand a 80% charge state and in many cases when this has happens your truck start battery never really returns to a good state after being recharged again.
As always one of the golden rules is to watch what you do with your Truck systems as this is usually the only way to get back home on...
Good planning prevails here...
Yes - I have been caught with my batteries down many times in my off road camping trips... My 2KW hand Crank Honda generator is my number one PLAN B on my trips...
Just saying...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
scrubjaysnest
I replaced the original charge line in the TV with 10 AWG and paralleled it with 8 AWG through a separate connector. Added a Shure Power isolator and breakers.
Paralleled the 10 AWG of the trailer with 8 AWG. This was mostly due to the 40 foot run from alternator to batteries. Breakers were also added at the trailer end. The result 14.5 to 14.8 volts at the batteries in the trailer with the reefer on DC. FWIW.
Axis 24.1 class A 500watts solar TS-45CC Trimetric
Very noisy generator :M
2016 Wrangler JK dinghy
โ€œThey who would give up essential Liberty, to purchase a little temporary Safety, deserve neither Liberty nor Safety.โ€ Benjamin Franklin
beemerphile1
The bigger the better but 10 gauge minimum.
SoundGuy
Golden_HVAC wrote:
The 7 pin has really small wires, perhaps #12, but likely smaller #14. And you need the ground wire to handle not only the battery charge 20 amps, but also the brakes 15- 18 amps, and all the running light amps as well.
Not true at all - standard recommended wire gauge for 7-pin Bargman connector.
2012 Silverado 1500 Crew Cab
Golden_HVAC
My buddy upgraded his wiring to #8 wire, and reported that his trailer battery will now fill up while towing from one location to another as long as he drives about 3 hours or a little more.
But because he wanted to stay put longer at a lakeside campground, he ended up buying a small generator and charges the battery with it. A solar panel probably would be a better idea.
If you install a pair of 120 - 150 watt panels on the RV roof, you should not have a problem with arriving with low batteries. SunElec.oom had 140 watt solar panels for $229 a few months ago. THey are 12 volt nominal (21 open circuit - what you want) and aluminum frames for attaching to the RV.
There are less expensive per watt panels without frames, but you don't want that one.
Some say to run a larger cord along with the factory 7 pin wiring. By installing a #10 wire, and a special plug, such as 277 volt angled plug (so your brother in law does not plug it into house power because it fits and blows up a battery). This connection is larger and can carry 25 amps with minimal voltage drop.
The 7 pin has really small wires, perhaps #12, but likely smaller #14. And you need the ground wire to handle not only the battery charge 20 amps, but also the brakes 15- 18 amps, and all the running light amps as well. Sure some of the ground amperage might be carried through the hitch to the truck frame.
If you buy some #10-3 wire from Home Depot, and run it from the battery to the truckbed, to a plug there, then #8 wire from the alternator to the relay that will shut off when the engine is off, then to the plug at the back of the truck, you will have maximum voltage to that plug while driving.
Good luck,
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a
Porsche or Country Coach!
I havn't been everywhere, but it's on my list.
Kangen.com Alkaline water
Escapees.com
GordonThree
Think not only about the vehicle side, but also Elkhart uses the cheapest wire they could between the trailer 7way and the batteries.
I'd recommend looking at a minimum of 4ga wire straight off the alternator, through an isolator or solenoid, all the way to the trailer batteries. Through a fuse in there somewhere too.
No I haven't done this but studied it in close detail. Instead of dealing with low voltage fickle DC, I ran an extension cord that allows me to run my small Yamaha generator in the truck bed and power the trailers charger directly.
SoundGuy
Centre pin on a 7-pin Bargman is an auxiliary, often used for back up lights when the vehicle is in reverse, Pin 4 is the charge line.
