Double Towing
houtrz
We have a VW Jetta and a Jet Ski I wanted to tow behind a motorhome. Can I tow both of these on a car dolly? I have seen a motorhome towing a truck four flat pulling a boat but wasn't sure about this.
13 REPLIES 13
UsualSuspect
You can't backup, and I doubt you will be able to see the jet ski or trailer back there unless you decide to go with a wireless camera behind the toad. Safe, depends on you, I have seen a tricycle with a drunk adult crash and injure a few folks, yet put a 5 yr old on it and they do just fine. I have a DP, and pull my D/A, is it safe, yes, would I put something else behind it, no, but I am not you.
2007 Fleetwood Excursion 40E Cat C7 350 HP
2007 Chev 2500HD D/A Long bed CC (Yes, it is my TOAD :B)
2011 Toyota Tundra
2013 Jeep Wrangler Unlimited Sahara (Backup towed)
Gone but not forgotten, 2008 Jayco 299 RLS
houtrz
I found a maximum length of sixty five feet but I can't find anything on brakes, not yet at least.
All the legal aspects aside, I was wondering what people thought of this particular set up, if its safe or not. I don't see a problem however I have never towed a car on a dolly much less having said car pulling a trailer too.
mowermech
Some states specify that the second trailer must be equipped with brakes which can be controlled by the driver.
What does YOUR state say?
Again, reciprocity probably does not apply!
CM1, USN (RET)
2017 Jayco TT
houtrz
Legal and length I'll be ok, I was more interested if towing this way, with the car on the dolly and the jet ski hooked to the car was safe or are there some safety concerns I don't know about.
mpierce
Lengthwise, if you are in a state allowing double towing, you should be all right. Just be sure to measure each one, add together, and be sure you are under 65'.
And, as mentioned, this is state specific, and you will NOT be able to go into all states.
houtrz
I sold my fiver a couple years ago and haven't been on the board much however we are about to purchase a Forest River Sunseeker 3050 which is a Class-C motorhome. It's equipped with a 7,500 pound hitch.
What I was wondering was if it was safe to put my car on a KarKaddy and tow the Jet Ski hooked to the ball on the car. I believe I can legally double tow in Texas I was just wondering if it was safe doing so. We have thought about trailering both but then we would have a 28 foot trailer and even an all aluminum trailer would be to heavy
j-d
One manufacturer of tandem dolly
Hikerdogs
Your profile shows you have a 5th wheel not a motorhome. If you've changed to a motorhome more information would be helpful. If you now have a class A or C gas powered motorhome the maximum towing capacity would be 5,000 lbs. Many models only have a 3,500 lb. towing capacity.
Tandem tow dollies generally weigh between 800 lbs. and 1,000 lbs. The car itself weighs between 3,300 lbs. and 3,600 lbs. depending on year and options.
A jet Ski weighs in the neighborhood of 800 - 1,000 lbs. The combination will run in the neighborhood of 4,900 lbs. to 5,700 lbs.
If the combination is on the lighter side it's touch and got for a motorhome with a 5,000 lb. towing capacity, and a definite no go for one with a 3,500 lb. towing capacity. If you have a DP with a 10,000 lb. towing capacity it shouldn't be a problem
Hikerdogs
2013 Winnebago Adventurer
tomman58
Wait you are in Texas. I've seen a Chevy truck,pulling a toyota truck, hooked to an older Buick that had a loaded large utility trailer going the the hills outside of Fort Stockton. Worse yer I seen it again (different car and truck) loading to the gills not more than 100 miles later.
The family was spread between the front trucks.
2015 GMC D/A, CC 4x4/ Z71 ,3.73,IBC SLT+
2018 Jayco 338RETS
2 Trek bikes
Honda EU2000i
It must be time to go, the suns out and I've got a full tank of diesel!
We have a granite fireplace hearth! Love to be a little different.
VoodooMedicineM
If the car and the jet ski are on the car dolly properly secured that would not be a double tow. You are only towing the car dolly.
Bill and Joey the dog
j-d
There are dolly's (and trailers of course too) that let you tow a car and something else like a motorcycle or jet ski.
Hikerdogs
This is one of those state by state decisions. In some states it's allowable in others it isn't. In Wisconsin the only way you can double tow is if the first towed entity is attached to the tow vehicle by a fifth wheel. Essentially that limits it to being able to tow a fifth wheel trailer and another entity behind the trailer. The most common combination is a truck with a fifth wheel, a fifth wheel trailer, and a boat behind the trailer.
Even then there are more hoops to jump through. You have to have a driver license endorsement for the specific combination, and the total length of the combination cannot exceed 65'. It can only be done on designated sections of the interstate highway system and a given distance from the exits. Several trucking companies tried double short trailer combinations a few years ago. However there are so many restrictions it's a rare occasion to see it happening these days. Needless to say here in Wisconsin they are trying to discourage it.
Also keep in mind there is no reciprocity between states for this type of arrangement. What might be legal in the state you live in isn't necessarily legal in other states you pass through.
Hikerdogs
donn0128
Since your in TX why not give DMV a call for accurate into?
