Driving with landing gear partially extended?
cchristanis
I tried doing a search on this but only found stuff on landing gear that doesnt answer my question. So, I have a torque 301 5er TH and was wondering about this. If there ever was an emergency and the TH disconnected from the hitch wouldnt it prevent major damage to the TH by having the landing gear partially extended or even fully (not that I would do that). I know the breakaway will apply the brakes but the front of the rv is going to drop and have some damage without a doubt especially at higher speeds. There is no way the gear is going to catch something in the road being extended a little bit. I have an andersen ultimate aluminum hitch by the way and absolutely love it! I have safety chains too but Im working on getting a different way to cennect them to the bed cause my Ram came with the 5er prep and the hooks are squareish. The safety chains dont connect to the hooks without adding something in between. I have to remove the ends and put different ones on. Here are pics to explain:
http://www.amazon.com/Andersen-Mfg-Ultimate-Connection-Safety/dp/B00J6ZGWXY
https://www.etrailer.com/p-RP30145.html
13 REPLIES 13
mlts22
I see this problem solved in four steps:
1: Insurance paid on both the fiver, tow vehicle, and liability.
2: A BedSaver installed.
3: Landing gear up completely.
4: A padlock on the handle once the jaws of the hitch are securely around the kingpin. This keeps little fingers that flip handles from causing damage.
tsetsaf
This query got me thinking... how many times have you ever heard of a fiver coming loose on the highway? I think there are a lot more things to worry about first.
2006 Ram 3500
2014 Open Range
"I don't trust my own advise!"
kaydeejay
NMDriver wrote:
I do not worry about the 5er falling off behind the truck. I do worry about it trying to come through or ride up over the back of the cab in an accident :(...............
Don't you think the lower front of the fiver ramming into the back of the truck will stop it?
Not sure what would make it "ride up", more likely to drop once the pin box clears the hitch..
Keith J.
Sold the fiver and looking for a DP, but not in any hurry right now.
BubbaChris
Horsedoc wrote:
TH ????
Toy Hauler
2013 Heartland North Trail 22 FBS Caliber Edition
2013 Ford Expedition EL with Tow Package
NMDriver
I never put mine all the way up, not because I think it will help in an accident but because it takes a long time and I do not like to hit the top of the worm gear with the leg nut. I generally use the manual leg extensions and only use the electric for 5-6 inches of travel to unhitch and level up.
I do not worry about the 5er falling off behind the truck. I do worry about it trying to come through or ride up over the back of the cab in an accident ๐Ÿ˜ž
I do have a bed saver and it has saved my bed twice. Once when I parked on a bunch of prairie dog holes and the legs sank into the ground after I started to pull out from under the hitch and once when I failed to engage the pin lock before doing my pull test. Real learning experience....Always do a pull test and always check the ground you are parked on.
5er/2500Duramax/18ftBoat
Community Alumni
Not applicable
Having towed a 5th wheel for many years in the past, if it comes unhitched while driving, the least of your problems will be damaging the landing gear! Having the landing gear particially down would never be an option to me.
Horsedoc
TH ????
horsedoc
2008 Damon Essence
2013 Jeep Sahara Unlimited
Blue Ox tow
azrving
cchristanis
Got it. Guess insurance would have to deal with it
valhalla360
Nomad III
Nomad III
At that point I would rather have the insurance company call it a total loss rather than have them "fix" it and then find out later there was more damage.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Old-Biscuit
Besides when 5vr comes disconnected it smashes the truck bed and tears up the tailgate........landing gear will not be of any saving benefit.
IF you are really concerned with 5vr disconnecting........get a 'bedsaver'
It is a safety catch device that captures 5vr king pin should 5vr come unhitched and stops damage to truck
Bedsaver
BTPO1
kaydeejay wrote:
There is a good chance the landing gear would simply fold under the front of the TH. Then what will you have gained other than bent landing gear!
X2, I don't have a 5er, but I agree with the above post. If you have that much mass moving it isn't just going to stop and drop on the landing gear with out folding the landing gear over. JMO
Jack
2003 Rexhall Vision 27'
2019 Chevrolet Equinox
States we have been to with this MH
kaydeejay
Keith J.
