electric sway control
me_camper
Has anyone used the electric sway control that uses the trailer brakes when it detects sway? Don't remember the manufacturer just wondering if anyone out there is using it and how it works. Thanks
2005 GMC 2500HD 4X4 Crew Cab
6.0L,4:10
2011 Coachman Freedom Express 296REDS
7 REPLIES 7
Lwiddis
Yes, Scott.
ScottG
That system and the system that comes on new trucks is not for ongoing sway control. It's for correcting a catastrophic event so you dont crash.
The truck and trailer should be set up so that never happens.
Lwiddis
"another Band-Aid" and " that thing is going to be applying the trailer brakes all the time to mask"
You guys should write GM and tell them how dumb and unsafe their idea is. But I do agree that proper loading is important.
mkirsch
Nomad II
Nomad II
Think about it for a minute... If you have a bad sway problem, that thing is going to be applying the trailer brakes all the time to mask the problem while you happily roll down the road, blissfully ignorant of the potential ticking time bomb behind you.
What happens when the brakes overheat?
This product is intended to stop an unforeseen, random, rare sway event, but people will use it to stop sway instead of fixing it the right way.
BenK
another band-aid...I'd just go with properly setup (OEMweight ratings, component classes, where those weights are, tongue weight of actual trailer weight, WD Hitch system dialed in correctly, etc, etc) than this...and...personally see it just another thing to potentially fail at the absolute worst time when Mr Murphy is crossing our path...
-Ben Picture of my rig
1996 GMC SLT Suburban 3/4 ton K3500/7.4L/4:1/+150Kmiles orig owner...
1980 Chevy Silverado C10/long bed/"BUILT" 5.7L/3:73/1 ton helper springs/+329Kmiles, bought it from dad...
1998 Mazda B2500 (1/2 ton) pickup, 2nd owner...
Praise Dyno Brake equiped and all have "nose bleed" braking!
Previous trucks/offroaders: 40's Jeep restored in mid 60's / 69 DuneBuggy (approx +1K lb: VW pan/200hpCorvair: eng, cam, dual carb'w velocity stacks'n 18" runners, 4spd transaxle) made myself from ground up / 1970 Toyota FJ40 / 1973 K5 Blazer (2dr Tahoe, 1 ton axles front/rear, +255K miles when sold it)...
Sold the boat (looking for another): Trophy with twin 150's...
51 cylinders in household, what's yours?...
Lwiddis
So far mine has worked great, and coming back from Bishop it was blowing up a storm on one trip. Others were moving around...I was not. So IMO GM's works but remember I'm only a 22 foot box...26 overall.
Hondavalk
