Electrical input from garage
onthebus
I have limited space in my garage circuit panel. I need to eliminate a 220 breaker. My question is since 220 is supplied at this time can I replace with 110 ( running through the same power cord) or will this damage something in the electrical system. I would like to run a small heater strip to limit humidity and lights in the winter months.
16 REPLIES 16
westend
Your electrical terminology is not up to the grade of an electrician. To answer, yes it can be done. You should seek help for the changeover to 120V service but you probably knew that.
'03 F-250 4x4 CC
Grit_dog
Navigator
Navigator
Look at mini breakers if you donโ€™t already have them. If so, you could very likely add the RV outlet and keep the 220 outlet (unless you donโ€™t need it and are using the same wiring and outlet (it sounds like)).
In general, I agree, if asking the question in the manner you did, get an electrician or someone who knows what theyโ€™re doing.
D_E_Bishop
If you are trying to get a new electrical service for the heater strip and lighting, MyRed Racer is correct. Just run an extension cord from an existing outlet to the RV and buy a dogbone to adapt the cord to what ever service you have in the trailer. If you already have power to the RV, just plug those things in.
MRR is also offering good advice regarding Moisture Rid or some other absorbent in the trailer. I had to do that at the beach one time.
Absolutely no reason to change breaker.
David Bishop
2002 Winnebago Adventurer 32V
2009 GMC Canyon
Roadmaster 5000
BrakeBuddy Classic II
Ron3rd
ScottG wrote:
Yeah, wrong forum but the answer to your question is yes, you can send 120 instead of 220 through the heavy wires without issue. You'll want to change the 220V outlet to a 120V 30A TT receptacle.
That's what I did at my former house. Just used one of the hot legs for my 30 amp rv outlet
Equilizer Hitch
Honda EU2000
myredracer
Other than the technical side of doing this correctly and being in the wrong sub-forum, what do you have for an RV and how long is it? TTs for ex. are poorly insulated and a heater can end up running non-stop just to keep it at a minimal low temp inside. I installed a permanent 1500 watt heater in our first TT which was only 20' long and it ran continuously and drove our power bill way up.
If you want to heat the interior to reduce the humidity level, why not use a dessicant dryer(s) or electric dehumidifier. If you use an electric heater, you also want to crack open a window and vent so moisture can escape.
For lights, do you mean the 12 volt DC lights running off the converter/battery? If that's all you need, could run an extension cord to an ordinary 15/20 amp receptacle.
drsteve
Have a friend with some electrical knowledge help you out. Wire it wrong and you can toast your electrical system, or hurt yourself.
Be safe.
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
wanderingbob
Also , not safe to assume heavier wires in 220 . What is the amperage of 220 breaker ? But yes it is simple to switch if wires are heavy enuff . It was common in Fl to run 220 volt shallow pumps on twenty amp wires and breakers .
wa8yxm
Short answer yes
Long answer it depends on the cable.
KD4UPL
You can possibly gain some panel space by installing a tandem breaker. These allow two single pole circuits in one breaker space.
rrupert
Giving advice on electricity is a liability.
Rich and Joyce
2018 Jayco Jay Flight 21QB
2012 Ford F150 4X4 Supercrew EcoBoost
Reese Strait-Line Dual Cam Hitch
Amateur Radio K3EXU
time2roll
Single pole breaker will give 120v to neutral. If that is confusing you need some qualified help.
SidecarFlip
One thing to always keep in mind with electricity and lack of experience / knowledge..
No one has ever seen electricity but many have felt it and many have died from it's impact. It only takes 5ma across your heart to end you tenure on this planet.
I'd suggest consulting a qualified electrician, home brew electrical can be lethal.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
wildtoad
Or perhaps, depending on your needs you could have an electrician tap into one leg of the 220 line to feed a 30 amp 120v TT outlet. In my case I have a seldom used window AC unit close to where I park the RV, and tied into to feed the RV. Still have use of the AC and can power the RV.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
ScottG
