F150 Questions
iagary
I have a 2014 F150 with 5L and 355 gears. my window sticker says nothing about a tow package but I have tow/haul, brake controller, 7 & 4 pin connectors and a small (approx. 21" X 3") transmission cooler. is there something else in a tow package that I am missing? Have been towing about 5500# with no problems. Do you all think I could move up to a 7000# gvwr trailer? I have a 4X4 super crew with 145" WB. as far as I can tell I am rated at 7700# towing capacity. Any advice is appreciated!
34 REPLIES 34
iagary
Where do I find payload or tare weight? GVWR is 7350#.
fla-gypsy
I didn't see the payload of the truck stated. With a 7k trailer TW could be 1000 lbs. If you have the necessary payload and have not exceeded any of the makers limits on any of the components you should be able to safely tow 7k provided everything is set up correctly.
iagary
Towing a 7000# GVWR trailer with this pickup, what gear should I be looking at? How many RPM"s? I seem to always feel best in the lowest gear possible, but then I think I may be "lugging" it too much. Thoughts on this please?
Thanks for all the help!!!
iagary
I did. It is the 7700# that I referenced below. Just asking about real world and how it will work.
phillyg
Go to the 2014 Ford Towing Guide to find out specifically what your truck is rated to pull.
--2005 Ford F350 Lariat Crewcab 6.0, 4x4, 3.73 rear
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
TNRIVERSIDE
Terryallan wrote:
iagary wrote:
Thanks everyone. Am I crazy to consider going up to a 7000 GVWR TT with this pickup?
good to go. You are well within the capacities of the truck. Have to remember. It does not take a HUGE trans cooler to do the job. 7700lbs is plenty of tow cap for that TT. However, IF you want to raise the tow cap. Put on a size smaller tire,( say go from 18s to 17s)
and flash the computer.
Does it also have a powersteering cooler? I bet it does.
Smaller tires to increase your tow capacity????
This might change your gearing but could also change you carrying capacity. Your towing capacity and your carrying capacity both need to be considered. Your F150 sounds like a good setup from the factory.
2014 Coleman CTS192RD. 2009 F150 4X4, 5.4, 3.31
Jeff
Atlee
You would lose your bet. The 2014 does not have a power steering pump. It has an electric motor.
Erroll, Mary
2021 Coachmen Freedom Express 20SE
2014 F150 Supercab 4x4 w/ 8' box, Ecoboost & HD Pkg
Equal-i-zer Hitch
Gonzo42
When I bought the tow package for my 2000 F-150 it included some relays.
MOTHER SHIP Winnebago View 24H (2007 Dodge Sprinter 3500 Chassis, 2008 Body)3.0 L M-B Diesel V6 bought used with 24K miles. Toad: ROCKY the Flying Squirrel.
iagary
Would the power steering cooler also be in front of the radiator? The only thing there is the trans cooler. I don't see one on the window sticker either.
Terryallan
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
TNRIVERSIDE
Load carrying capacity might max out. With a tongue weight of 700 to 800 pounds and the gear and passengers your load carrying capacity migh be exceeded. Just something to consider. I am not the weight police.
Jeff
tragusa3
I don't think so, but realize you may be stressing things and causing wear quicker than if you had the other items. I bet the towing experience itself would feel fine.
New to us 2011 Tiffin Allegro Open Road 34TGA
Join us on the road at Rolling Ragu on YouTube!
iagary
Mvander
You have regular tow pkg and the ibc comes with many packages or could be ordered stand alone.
55 FEET OF FAMILY FUN!
2014 F150 HD
2015 Grey Wolf 29DSFB
3oaks
Towing mirrors are no longer included with the Max Tow Package on the new Ford F150s. They must be ordered as a separate optional item. Made no sense to me or my dealer when I ordered a 2016 F150.
