โJul-09-2017 08:21 AM
โAug-01-2017 05:15 PM
โAug-01-2017 03:02 PM
โJul-11-2017 12:49 AM
โJul-10-2017 05:07 PM
โJul-10-2017 04:46 PM
โJul-10-2017 03:59 PM
Old-Biscuit wrote:jamnw wrote:
I have an appointment with CW in Biloxi, MS on July 24th. I have the Good Sam Extended Service Plan.
Should I go ahead and call the warranty company or wait for CW to do this? Experienced answers are greatly appreciated.
Don't those 'extended service contracts' REQUIRE prior authorization???
YOU need to be 'LEAD' on getting authorizations be it 'service contract' or Insurance coverage
โJul-10-2017 03:29 PM
โJul-10-2017 03:09 PM
โJul-10-2017 03:07 PM
TurnThePage wrote:BB_TX wrote:I wonder when this came to be? My 2004 trailer has nothing like that.
All the 12 v wiring should have either fuse or circuit breaker protection fairly close to the battery to protect against that type event. I would look for a shorted positive wire near the battery. And/or possibly a circuit breaker that failed to open when a wire associated with the slide shorted. . Happening during opening the slide would seem to point to some relationship there.
โJul-10-2017 03:06 PM
nickthehunter wrote:
I don't believe fire is a extended warranty issue. That's an insurance issue.
โJul-10-2017 12:49 PM
โJul-10-2017 11:43 AM
wa8yxm wrote:Not exactly accurate.. Go outside and look UNDER your tank. There you fill find what appears to be a capped-off access to the tank. Thats an over-pressure valve that releases a LOT of gas and is REALLY loud, and theres no way to shut it off if it fails
Propane tanks are designed NOT to blow for several hours. by then the Professionals will usually have knocked the fire down
Suggestion.. Google "Mac the fire guy" and buy some GOOD extinguishers.. He will tell you what you should have instead of that toy the factory installed.
โJul-09-2017 07:05 PM
โJul-09-2017 04:57 PM
โJul-09-2017 01:48 PM
