Flat wheel towing
marktwebb01
I am new to RVing and looking for a vehicle to flat wheel tow. Any recommendations?
12 REPLIES 12
lryrob9301
Here is the correct link to MotorHome Magazine Dingy Towing Guige
Hank85713
You didn't specify auto or manual, new used or really what you want, car vs truck so its really hard to say what is good. I have a 94 ranger pu, was going to tow but it weighed in at almost 4000 lbs. Looked around at other stuff ended up with a 13 Hyundai Elantra at 2800lbs. Both are manual trans. Supposedly wifes honda accord could be towed but its a honda so we looked for alternatives. The hyundai is not expensive for a new vehicle has good storage room with rear seats down, get in the 30's for mileage and is maneuverable. SO you just need to know what you want or better explain your requirements.
mowermech
ALWAYS read the Owners Manual for the vehicle being considered for use as a toad!
ALWAYS!
It is the ONLY real source for information about the towability of the vehicle.
However, it is also true that people HAVE towed vehicles that are not considered towable by the manufacturer. They are willing to take the chance that the transmission will not self destruct due to lack of lubrication.
In truth, ANY vehicle, with ANY transmission, CAN be flat towed, IF the owner is willing to pay the price in transmission repairs or replacement. The destruction of the transmission may take place in 100 to 500 miles, or it may last for thousands of miles. There is simply no way to tell!
Vehicles I know to be towable:
Subaru AWD, maanual transmission (automatic transmissions NOT towable)
Almost any Jeep (there are exceptions, read the Owners Manual for instructions)
Almost any 4X4 that has a Neutral position in the transfer case (again, there are exceptions, read...)
Volkswagen original Beetle, Karmann Ghia, and Thing
Good luck in your search.
CM1, USN (RET)
2017 Jayco TT
Daily Driver: '14 Subaru Outback
1998 Dodge QC LWB, Cummins, 5 speed, 4X2
2 Kawasaki Brute Force 750 ATVs.
Pride Raptor 3 wheeled off-road capable mobility scooter
"When seconds count, help is only minutes away!"
ronfisherman
Moderator
Moderator
Moved from Class C.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
sdianel_-acct_c
http://192.168.1.1:8181/http://webcontent.goodsam.com/motorhomemagazine.com/2015DinghyGuide.pdf
this might help. 2015 Dinghy Towing Guide.
There are other years available on the Motorhome Magazine website to download for a small charge.
Basically most manual transmissions can be towed 4 down and some 4 wheel drive automatics. We tow a 2008 Chevy Colorado 4WD, 4 door pickup. Easy to set up to tow 4 down. Don't know about the new ones.
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
lanerd
I don't think you would want to tow any vehicle with flat wheels....do you? :p:E
That said, I'm sure you're referring to towing a vehicle with all four wheels down as opposed to a dolly with two wheels up or a trailer will all four wheels up.
Many, many of the domestic vehicles with auto transmissions are capable of being towed 4-down; however, there are few import vehicle that can. GM, Ford, and Chrysler all have lots to choose from.
If you have a particular vehicle in mind, you can go to: REMCO and plug in the info needed and it will tell you if it can be towed 4-down or requires a transmission lube pump or a driveshaft disconnect.
I noticed you posted in the Class C forum. Please be aware that most class C's are weight limited to a max of 5000 pounds (and some only 3500 lbs) towing. Check your owner's manual for this info.
Good luck in your search...
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
Gooding__R
I have pulled a Chevy HHR behind my "C" for years now with on problems at all.
dicknellen
check out the dinghy towing forum on this web site
carringb
Ford has the largest range flat-tow offerings. Some folks had trouble with the Dual-clutch transmissions in the small cars (Fiesta, Focus) but as long as the short towing procedure is followed (basically, waiting for confirmations it is in neutral before killing the ignition) they rarely have problems.
2014 ORV really big trailer
2015 Ford Focus ST
Nutinelse2do
Chevy Tracker, Suzuki Grand Vitara, Saturn, Honda CRV
Living Our Dream
MTHRSHP - 2006 KSDP 3912
Cummins 350ISL...Spartan Chassis
ESC POD - 2019 Ford Ranger XLT FX4
Zippy Scoot- 2018 Honda PCX 150 on an Overbilt Lift
Shredder at the Rainbow Bridge - You Will Always Be With Us
jaycocreek
I towed a Mazda pickup(4 speed) with my Beaver class c.Inexpensive compared to tow dollies etc.I'm looking for a tow dolly for my front wheel drive Dodge Caravan and the cheapest I can find so far is $600..
Lance 9.6
400 watts solar mounted/200 watts portable
500ah Lifep04
Triker33
Used HHR
New MKS, MKZ
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
