Hard twin 40# propane tank cover
WallynDiane
Does anyone know if a hard twin 40# propane tank cover is available?
I can only find vinyl covers for twin 40# tanks.
Just setting up our new Kropf Park model. Thank you.
5 REPLIES 5
bobsallyh
I have a friend who has two 40s on his Avion(Airstrean wanna be)that took two covers, put them together and used aluminum trim over the joint. Looks great!
2_many_2
WallynDiane wrote:
Pricey indeed. Almost $700. Vinyl covers are starting to look like my only viable option.
Thanks all.
With Tax and shipping probably more like $800, Old-Buscuits idea to make one out of two plastic ones sounds good to me. You could slide the top over the bottom half covering the cut seam. I think it would look like factory.
WallynDiane
Thanks all.
2_many_2
Airstream makes one HERE but like everything Airstream, it is pricy.
Old-Biscuit
Have never seen any 'hard covers' for 40#
Have read of several folks 'looking' for hard and never found them
20#, 30# and 40# cylinders are same diameter and 40# are 5" taller than 30# (29" vs 24")
Have seen where some have taken TWO hard covers and made a taller set (Two 20# covers------cut bottom section off and pop riveted to other cover or One 20/One 30)
