Hot Water Tank Noise
Whiskey_River
Using city water @ 40psi I have a noise coming from the hot water tank that sounds like a motor running. It is a Suburban 10 gal elect & gas model. It makes the same noise regardless weather the water is hot or cold, ie just turning on the hot water before it gets a chance to heat up.
I changed the check valve at the top of the tank in the back used for winterizing, changed the anode rod, and open the pressure valve on the tank to let out any built up air pocket.
The tank is in an 09 fifth wheel, so it is not that old & started to make the "motor" noise about a year ago. It works fine & heats on either electric or gas.
Any ideas, or just learn to live with it???????????
8 REPLIES 8
larry_barnhart
We have wintered for 6 months in az since 2001 and I am always surprised on how many rv'rs have never known about the air chamber.
chevman
chevman
2019 rockwood 34 ft fifth wheel sold
2005 3500 2wd duramax CC dually
prodigy
KSH 55 inbed fuel tank
scanguage II
TD-EOC
Induction Overhaul Kit
TST tire monitors
FMCA # F479110
Whiskey_River
OK thanks all.... It does just make the motor noise when the water is running. I put in a new check valve because last year when I was winterizing it, the old one would not stop the pink antifreeze from coming back into the tank. It only cost 6 bucks but is not the easiest to get at. So if it works to winterize, I will just learn to live with the "motor" noise.
Old-Biscuit
fla-gypsy wrote:
If it only makes noise when water is flowing it is coming from the check valve.
X2
That's the only moving part in WH.
If it makes noise while heating using the electric element...element is coated in calcium/scale
Air pocket is suppose to be there to allow for the expansion of the water as it heats so high pressure is not built up.
Turn off water heater
Turn off water supply
Open faucet hot side to relieve pressure
OPEN PRV via lever.hold open until water stops flowing then let if snap shut
Close faucet
Turn on water supply
Air pocket re-established.
fla-gypsy
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
09 SuperDuty Crew Cab 6.8L/4.10(The Black Pearl)
06 Keystone Hornet 29 RLS/(The Cracker Cabana)
stuplich
I changed the check valve at the top of the tank in the back used for winterizing, changed the anode rod, and opened the pressure valve on the tank to let out any built up air pocket..
Whiskey River
There is supposed to be a "head of air" in the WH tank!
Re-establish the necessary air pocket and try again!
Don't open the P&T valve and let the "air pocket" out!
Mel
'96 Safari
ScottG
It's probably the check valve. Many, like mine, have been noisy since new.
Doesn't bother me so I leave it as is.
camperpaul
It sounds like you may have calcium (lime)build up inside the tank.
Paul
Extra Class Ham Radio operator - K9ERG (since 1956)
Retired Electronics Engineer and Antenna Designer
Was a campground host at IBSP (2006-2010) - now retired.
Single - Full-timer
2005 Four Winds 29Q
2011 2500HD 6.0L GMC Denali (Gasser)
larry_barnhart
I have not had a check valve for years but last winter I had to removed the rear panel in the basement so I bought a check valve and it doesn't the same as yours. Friend also had the same noise but the fifth is 5 years old so when the new check valve made the same noise as his I was not a happy hot water camper. Now it is ok because I gave up and let it do it's thing.
chevman
chevman
prodigy
scanguage II
TD-EOC
TST tire monitors
FMCA # F479110
Type a product name
