โApr-25-2016 05:52 AM
โApr-26-2016 09:48 PM
MetalGator wrote:SolidAxleDurango wrote:
Was the water already HOT when you turned on the propane? Maybe it didn't fire right up because it didn't' need to??
Yes, the water was still hot. I had turned off the electric switch but it had only been off 30 minutes or so. I kind of had this thought myself but the second time I had the electric turned off about an hour but the water was still pretty hot.
โApr-25-2016 11:59 AM
โApr-25-2016 11:48 AM
โApr-25-2016 11:26 AM
Old-Biscuit wrote:
Remove the cover on the set ot t-stats (Push to Reset cover)
The right side set of t-stats (RED Wiring) will be for the propane
Bet the connector wire from HI Limit (Reset one on top) to the Normal Temp (bottom) is burnt into. It was the one you probably had to reset.
Buy a new '12V DC' set of t-stats and replace.
(FYI left side is 120V AC for the ----BLACK wires)
โApr-25-2016 11:16 AM
โApr-25-2016 06:49 AM
โApr-25-2016 06:41 AM
โApr-25-2016 06:37 AM
โApr-25-2016 06:23 AM
โApr-25-2016 06:18 AM
โApr-25-2016 06:08 AM
โApr-25-2016 06:02 AM
