โMar-28-2016 09:11 AM
โMar-29-2016 05:01 AM
โMar-29-2016 04:15 AM
IDoMyOwnStunts wrote:Same here. We fill the gray much faster than the black. I added This Valve for this purpose.
I do that with a Flush King, but slightly differently. My grey tends to fill much faster when we have FHUs, so I almost always have a black tank at 1/3 when my grey is full. I just transfer some grey into the black and re-close both valves instead of dumping the entire grey. That usually nets me an extra day of grey use. Plus more water sitting in the black is better.
โMar-29-2016 03:37 AM
โMar-29-2016 12:27 AM
Memphisdoug wrote:
I would leave both closed and then dump both when the first one fills. Like tonymull says, if you leave the grey tank open there isn't enough water going through all the time to flush things out and down your sewer hose well
โMar-28-2016 10:57 PM
Johnny G1 wrote:
Leave both closed and open black only to dump and then back flush black tank with a bit of grey water, do this 2-3 times and the black tank will be a lot cleaner, Trust me we have tried it all and my method works the best for me, you can leave a lot of stuff in the black tank other wise that you won't get out. Just my thought's.
โMar-28-2016 07:29 PM
โMar-28-2016 05:36 PM
โMar-28-2016 04:37 PM
โMar-28-2016 04:28 PM
โMar-28-2016 02:58 PM
โMar-28-2016 02:54 PM
โMar-28-2016 02:08 PM
tonymull wrote:
Prefer to keep both closed. When the black needs to be dumped do so, then empty whatever is in the gray tank behind it. Leaving the gray open will encourage food debris and grease buildup just like leaving the black open encourages poop buildup.
โMar-28-2016 01:45 PM
โMar-28-2016 12:51 PM
