How to prevent Keirig from freezing??
ivbinconned
It has been suggested that we run some whisky through it.
Is there a better way other than keeping it in the truck/motels for 3 day?
Ram and 34 ft Cedar Creek
33 REPLIES 33
magicbus
For those wondering why the OP lets his trailer get so cold while heโ€™s using it, it appears to be because when the temps are really low he stays in a motel. I suspect this is why he mentioned keeping it in the truck/motel for 3 days, probably while heading south.
Dave
Current: 2018 Winnebago Era A
Previous: Selene 49 Trawler
Previous: Country Coach Allure 36
StirCrazy
Navigator
Navigator
you can't with out putting **** in it that will give you off flavors or wreck pump seals and such. I think we have gone through a couple before I figured out that even when you empty them by the instructions they are not truley empty. we take ours in the house when we winterize the rv and take it back out when we get ready for that first camping of spring. if we have to use the rv during the winter I leave it at home and use the stovetop perculator.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
ajriding
Even cheap wine at 5% will not freeze solid, just to a slush that will not break anything.
I too am puzzled why your RV is so cold when in use. What do you do with the water system? If it is stored then duh.... take your toys in the house...
I always tell people, if you're going to go camping then learn how to camp.
There are many many ways to make coffee in a camper that do not require warm storage. Get with the program.
blofgren
OP, you could run some cheap vodka through it (although I realize that it's not nearly as cheap in Canada as it is in the US). It wouldn't take much, and there would be no aftertaste from it. Or you could make some great "coffee" when you get it going again. :B
I have actually heard of folks using it to winterize their RV's.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, B&W RVK3670 hitch, Retrax, Linex, and a bunch of options incl. cargo camera
2008 Corsair Excella Platinum 34.5 CKTS fifth wheel with winter package & disc brakes
Grit_dog
Navigator
Navigator
Always entertaining when a โ€œhow to keep water from freezing in cold temperaturesโ€ topic comes up. Especially when the proposition is to โ€œrun whiskey through it!โ€
Walaby
If it's cold enough for your Keurig to freeze while you are in the camper, with heater on (because it is cold), then can't help ya.
If your RV is parked for the winter, take the Keurig home with you and keep it in your nice toasty home.
Mike
Im Mike Willoughby, and I approve this message.
2017 Ram 3500 CTD (aka FRAM)
2019 GrandDesign Reflection 367BHS
Bobbo
RetiredRealtorRick wrote:
How would it freeze if there's no water in it?
I'd imagine if it were a concern, I'd buy an insulated ice chest it would fit into and let it live there until I needed to use it.
It will still freeze unless there is a heat source inside the cooler.
Really? So a putting it inside a well-insulated cooler, in a somewhat-insulated RV would not keep it from freezing? Exactly what kind of outside temps are we talking about here?
The insulated cooler and insulated RV won't keep it from freezing. It merely takes longer for the temperature to drop low enough around the Keurig. Without a source of heat, the inside of any insulated container will eventually reach the temperature of the outside. The insulation just slows that process down.
Bobbo and Lin
RetiredRealtorR
. . . never confuse education with intelligence, nor motion with progress
pbeverly
In regards to the landfills, K-Cups are recyclable. All the ones I buy state that and tell you what to do. Peal the top off, dump the coffee, rinse, put with recyclables.
Now, do I do this? NOOOO!! When they make it easy to pull the top off I will, right now it is a PAIN.
I use a cheap no name K-Cup brewer, OK, it has a name, but nothing I have heard of before, that makes a single cup and pretty much sucks all the water out each time.
Ridgeway, SC
2019 26DBH Grey Wolf
RedRollingRoadb
wa8yxm wrote:
The lowest end Kuring is one where you pour your water in and it uses it all up running itsel dry (you will hear the pump run free...
We have one of the single serves also. Couple of times we have taken off for a long weekend in winter we will just grab the few cloths and some food and go to the storage lot. It takes us 15-20 minutes to settle in.
We get done and decide to make coffee to go. Keurig wouldn't work. Drove to destination and decide to re-check it before I trash it and it fires right up. Did this twice. Finally decided it just doesn't like to work till it gets warmed up to above 45.ยฐ
Grit_dog
Navigator
Navigator
ivbinconned wrote:
Wa8 Donโ€™t worry about us filling landfills with cups.
I cut them open, shake out and compost the grounds.
Then because there is a tiny amount of oil in each cup I use them to help start the fires in the wood stove we heat our house with.
I love to watch the black smoke going skyward and the spreading out all over the country side from witch the product originally came from.
Although if I run out of Kcups I burn railway ties and they really pour out the black smoke!!
Iโ€™d advise to only burn those at night so your neighbors donโ€™t see the black smoke.
But it sure does through the heat when itโ€™s -40 degrees out side.
Like button!!
jkwilson
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
ivbinconned
Grit_dog
Navigator
Navigator
:S
ivbinconned
We had one freeze and break even though we were sure it was drained.
