โMay-29-2017 05:59 PM
Moderator edit to re-size picture to forum limit of 640px maximum width.
โJul-06-2017 07:25 PM
โJun-29-2017 07:00 AM
โJun-28-2017 03:57 PM
tinner12002 wrote:schlep1967 wrote:
To all of those that say it looks safe, after the coupler becoming disconnected or the ball/nut becoming unthreaded, the pin holding the hitch in the receiver is just about the only other possible failure point causing loss of trailer. If the cotter pin comes off of the pin and the pin slides out, what is going to activate the brakes?
What if and what if! We can all what if this happens, well what if your frame breaks, and what if when it activates the brakes don't work, you can only take so many precautions for what if.
Personally I would hook mine that way, actually it looks kinda thought out to me, much better than just hooking cable on the safety chain hook which many do.
โJun-28-2017 03:12 PM
BenK wrote:
Anyone guess where this goes with where I clip on my safety stuff?...
โJun-22-2017 04:27 AM
โJun-21-2017 05:06 AM
Moderator edit to re-size pictures to forum limit of 640px maximum width.
โJun-08-2017 04:40 AM
marininn wrote:There is nothing wrong with the threaded chain links provided they have the proper rating.
Someone mentioned that the threaded chain links will break, explain further???? They are rated at thousands of lbs, so why they break? What is the best option?
โJun-07-2017 09:57 AM
โJun-07-2017 09:23 AM
โJun-01-2017 08:25 PM
NJRVer wrote:Lantley wrote:NJRVer wrote:Terryallan wrote:
Never Never Never hook the lanyard to the hitch. As mentioned. IF the hitch breaks, the brake pin will not be pulled. Will be useless.
I put a I-bolt thru the step bumper where there is a place for chaines to be hooked if using the bumper to tow. I hook the lanyard to that. So that even if the hitch fall off, the brakes will still be pulled on.
I think I have more faith in the hitch than I do in a bumper.
It's not about faith. The whole premise of the brake and cable is that a failure can occur. If failure occurs it is wise to have cable attached to anything other than the point of failure
If you take it to the nth degree, a failure can occur no matter where you make the connection.
โJun-01-2017 07:49 PM
โJun-01-2017 07:25 PM
โJun-01-2017 06:23 PM
โJun-01-2017 05:33 AM
