โOct-04-2021 08:22 AM
โOct-07-2021 02:41 PM
โOct-07-2021 02:28 PM
โOct-07-2021 07:48 AM
โOct-06-2021 01:09 PM
walker111 wrote:
Update
Pulled both batteries out ( trojan t 105 about 3 years old and brought them home. Checked water levels and noted the water was below the plates so added distilled to all 3 caps in each battery. Cleaned everything up and put them on a trickle charge. This morning they read 12.69 V ( but this is while they were hooked up) so they were not charged and lacking some water.
I hope this is my issue!!!
I will check after work today and that will have given them 24 hours and check strength. I think it should be around 13.4??????
Thought about running the jumpers to the motor like suggested to check for fun but delt with this first. That is how I run my genny during the winter months when going over to check things and exercise the genset.
I did see dirt piled on the tops of the legs so these will need me tending to them when I tow it home again.
Of note. My rig is a 50 amp service and I rarely ever find 50 amp. It is usually only 30 and works for a few days but I know some of my electrical draws are not on the legs of the 30 amp. Example is, when I am plugged to shore power 30 amp my batteries are not charging as per the indicator lights.
Weird but I did not wire the unit. My electric option for hot water tank does not work on the 30 amp either as well as many of my receptacles .
I may have to look into this .
I would have thought that running the genset would have lifted the trailer but in this case no with the batteries in the condition they were showing. The battery light indicators in the trailer were not the tell all.
Thanks all for replies. Again I hope this is the issue!!!!
โOct-06-2021 08:24 AM
โOct-05-2021 10:07 AM
โOct-05-2021 07:53 AM
โOct-05-2021 07:00 AM
JRscooby wrote:schlep1967 wrote:
If it's like mine there should be 2 wire nuts about 6 inches from the motor. Take those off and separate the wires. Hook your jumper cables directly to those wires and your trailer battery.
Warning! Yes, it will make a spark. Better to hook the cables to the battery, then to the wires. It will still spark, but the spark not be right at the battery. Much less chance of a explosion.
โOct-05-2021 06:33 AM
โOct-05-2021 04:20 AM
โOct-04-2021 02:40 PM
โOct-04-2021 02:22 PM
โOct-04-2021 02:16 PM
โOct-04-2021 01:48 PM
