โAug-04-2015 09:36 AM
โAug-08-2015 11:07 AM
โAug-05-2015 08:48 PM
Ready Brake's FAQ wrote:
What other issues could I run into?
Tow bars need to be level to the ground when installed correctly. The National Standard for correct tow bar levelness is (+) or (-) 2" inches. This allows for a forward push by your towed vehicle. Having the tow bar too far from level puts a great deal of stress on your towing system and can also cause you to lose control of your RV in adverse conditions when heavy braking is applied. To measure levelness just subtract the difference in height of the center of your RV receiver from the ground with the height of the center of your baseplate tabs on the towed vehicle from the ground. Most baseplate brands list an approximate tab height for each vehicle on their websites if you do not have a baseplate installed to measure yet. If a drop or rise is needed we also manufacture hitches for this.
โAug-05-2015 06:24 PM
โAug-04-2015 01:38 PM
โAug-04-2015 12:31 PM
โAug-04-2015 10:16 AM
