Motorhome vs travel trailer for cross country with pets??
Tortiemctortiep
Hello!
I have been trying to research the pros and cons of each and am finding myself getting more confused!
I am planning on relocating from VA to WA next summer, and also taking the summer to explore along the way (I work in schools so have my summers free). I will be moving with my pets (two medium dogs, a cat, 4 small birds, a bunny, a tortoise, and a snake).
Safety is my biggest concern, both for my pets (needing to have climate controlled places for them to be) and myself (as a woman traveling alone), but I donโ€™t know which option would be the safest option...
A motorhome would be climate controlled, but I can probably only afford an older one (I have seen some mid-1990s to early 2000s listed that could possibly be in my price range), and I worry about how reliable they would be going over mountain passes, and if they did break down the ease of getting them repaired (finding parts, etc.). Also if it broke down and I had no ac, how to keep the pets cool in the meantime... unless I kept my current vehicle (Nissan Rogue) to tow behind and loaded them in there.
I have read that a travel trailer could possibly be rigged up with a generator in the bed of the towing truck to be climate controlled while driving, but I would have to buy a truck capable of towing a travel trailer. With a crew cab at least some of the pets could ride with me in the tow vehicle and be transferred to the trailer at night. A newer truck would be a big stretch on my finances, but might possibly be more reliable and easier to have fixed if broken down? I was initially considering an SUV with a travel trailer, but I have been told that the transmission wouldnโ€™t be able to handle that much towing and that a full size truck would be best.
I would appreciate any and all suggestions from experienced travelers!!
47 REPLIES 47
badsix
we have a crew cab and 45# Boxer. the rear seat 3/4s of it folds up and makes room for a dog bed. i leave the other seat down so she can get up on it and hang out the window when she wants to. she likes it.
Jay D.
Tortiemctortiep
Okay, that is good to know!! Thanks for the tip, it seems water damage is a very common issue to be on the lookout for so itโ€™s good to have ideas of where to look for it.
olfarmer
I think you might be wise to go Class C with a small tow car. Class C's are not much harder to repair than any van and not having to move the animals all of the time would be much easier. If you are used to driving an ambulance that makes a lot of sense. I would caution you to look carefully for roof leaks etc. especially in the cab over bed area on a Class C. Many tend to leak there.
Ed & Ruby & the 2 cats
2001 Winnebago Brave 30W
7.4 gas Work Horse Chassis
99 Jeep Grand Cherokee
Tortiemctortiep
I canโ€™t thank you all enough for all of the great information and advice!
I was leaning toward a van/suv with travel trailer combo, but I am now reconsidering the class c as a possibility, for two main reasons... One is that I am used to driving ambulance sized vehicles (well, because they are ambulances :D) so the idea is much less overwhelming to me and seems like it would be easier to maneuver in general. Two is that when I was trying to plan out where to keep the pets in each place and to move them back and forth between tow vehicle and trailer... it got really messy and I think that might be more stressful for the small pets being transferred into travel cages for the day and then back... versus just setting them up nicely in one spot in a motor home and letting them settle in. I could even potentially keep most of them in their current enclosures, depending on space available, rather than having to downsize everybody.
Iโ€™ve been thinking hard about the break down scenario, as that was the biggest reason for my tending toward a travel trailer... and I think I can work it out. I will still have tiny travel enclosures that will fit into backpacks and/or duffel bags for everybody in the event of needing to take everybody with me somewhere. Instead of being an everyday transition thing though this would just be in case of a break down. Iโ€™ve found ways to stay in hotels before with pets (I did that every night on the trip from WA to VA) or if push comes to shove I can maybe stay a few nights in the small car I plan to tow behind (I think I could trade my Rogue in for something small that is flat towable).
My original concerns about reliability of older class cโ€™s remain though as most in my price range are 1980s/90s/early 2000s. Are there any makes/models that just have great reputations? Or ones I should avoid?
I am still thinking this through and am very much in the planning stage, so I continue to welcome any advice!!!
CFerguson
Tortiemctortiepants wrote:
Thank you everyone!! I knew I was lost but now Iโ€™m realizing how much I really donโ€™t know about this... it had never occurred to me that campgrounds would have age limits for rvs or pet limits... your advice has been really helpful.....
Dont get too concerned about the 10 year rule some CGs have (i have seen several that have that in their rules). It has been discussed here a lot and the concensus is that it is a rule that is in place to exclude junky old trailers(and people) and is rarely applied. If your RV is in good shape and looks good, no one is going to bother you.
valhalla360
Nomad III
Nomad III
Thatโ€™s true that it would be better to still have a place to be with the pets in the event of a break down... but If my towing vehicle did break down, say on the side of the road, do tow trucks tow both the vehicle and the trailer?
Basically they would charge for 2 separate tows (mostly a cost thing) but yes, they can get you to a campground while the truck is repaired.
As someone else mentioned, with a Class C, the drivetrain with low miles may not tell you much. Most go to the junkyard due to leaks in the house portion, not wearing out the drivetrain. So a $6k unit with low miles may still be a steaming pile of poo. As you aren't familiar, find a local independent RV tech and once you think you have a good option make an inspection part of the offer. It may cost you a couple hundred but if it steers you away from a bad deal, it will be well worth it.
As long as the RV appears in decent shape, I wouldn't worry about age. That's mostly a southern snowbird thing where people stay in a park for a few months. Really age is just a surrogate measure for eliminating junky rigs. What we've found is if they look out the office window and the rig looks good, they "forget" to ask about the age. For your trip in the summer with just short term stops, asking about age has never came up as a question.
I would still be very careful with the SUV option. Dig in and fully understand the limitations. Most of the smaller ones really have very limited capability. Truck payload often runs out prior to tow rating. Especially moving, I expect, you will want to pack the truck full of your stuff, so you could easily wind up over payload with an SUV. Even with Pickups and Vans, you need to watch it but it's far easier to find one with good payload capability. SUVs are built for comfort not payload. The only ones I would consider are the big Suburbans or the Ford Equivalents. Even then they often are not as good as their pickup comparables.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
pitch
Like I and others said earlier Full size van and travel trailer.
In the rare occurrence of a breakdown they send one(1) truck. A roll back. wheel lift trucks are mainly used for recovery and repossession, with a rollback being the most common for break downs. Van on the truck trailer hitched to the tow. When you are on the phone with the service or garage tell them you want a roll back.
Van and TT
Don't let people on here get you all worked up. This is not rocket science even though many act as if it is.
A 16 to 20 ft travel trailer with a gross weight of 6k behind almost any full size van. The only pets campground care about are dogs. Don't even mention the rest. When you find a van have a mechanic put an auxiliary transmission cooler on probably about 3 hundred bucks. Figure 10 miles per gallon at best and an average of 40 bucks a nite for camping. Don'tworry about any ten year rule. It is only the snobbiest of resorts that have it.
olfarmer
Usually most RV parks even ones with the 10 year rule go more by appearance that the actual age. the rule just gives them a reason to keep a junky looking RV out. This is not always the case but I have had several older motor homes and have never been turned away. I keep them looking as close to new as possible. My current rig is a 2001 Winnebago Brave that I have had several years. It has around 30k miles on it and I have never had any appliance problems but I have had 2 problems with the chassis, one was an in tank fuel pump $$$$ and one was a brake issue. As far as the AC going down the road, in moderate weather the dash AC will keep the house cool enough for most animals but if it gets too hot it is not a big deal to run the generator and the roof air. I think you really should either have a tow behind vehicle with a MH in case of break downs so you have a place for the pets or it sounds like a trailer with a van or big SUV would be the best for you and the pets.
A class A or Class C in the mountains is not a big deal but towing a heavy vehicle behind it in the mountains may be, My MH does not like towing my Jeep over a big steep grade, the engine is OK but the transmission heats up!
time2roll
There is a 96 Minnie Winnie with 50k miles on it for sale near me for $6500, and Iโ€™m considering looking at it but Iโ€™m just worried about its reliability as an older vehicle... Do the low miles negate its age a bit?
Thanks again!!
This is a very realistic option. While you need to test drive to verify the driveline is functioning well... probably even more important is looking for water damage from roof or window leaks.
But really if something like this would work for 3 to 5 years you will get the money out of it. Don't worry plenty of RV parks take all comers. Just stay away from the fancy ones.
Mickeyfan0805
RV Specific roadside service account for this. Your tow vehicle can be towed for service and your trailer can be taken to a local campground. It's not as simple as all that, but it's better then standing outside an RV dealership with a bunch of animals and nowhere to spend the night.
Tortiemctortiep
DrewE wrote:
Certainly not at the same time, at least not generally. I suppose it may be at least theoretically possible for a flatbed tow truck to haul both if it has an ordinary hitch receiver and the right sized ball and so forth, but that would definitely not be something to count on. A wheel lift tow truck definitely isn't going to tow a disabled vehicle plus a trailer behind that vehicle.
You can of course get the tow vehicle towed for repairs and also make arrangements to have the trailer towed to some other location, either by renting a vehicle that can tow it (and is permitted to per the rental agreement), or by hiring someone, or by relying on the kindness of some helpful person you somehow meet or know.
Oh my! That sounds like it would be quite the ordeal to have to arrange towing for two things instead of just one!
Tortiemctortiep
Iโ€™m still torn between the class c and travel trailer options.. but Iโ€™m ruling out the truck idea as I think I am going to need the pet space I would get with a van/suv (with ac in the back area) , if I go the travel trailer route. I got scared off of the SUV idea because people told me that I would burn the transmission up towing... Iโ€™m guessing that it would be okay as long as I was within the correct weight limits?
DrewE
Tortiemctortiep
Mickeyfan0805 wrote:
The pet thing is hard. I would take some time to consider some examples of campgrounds in which you'd be interested and then explore their pet policies. Make sure you'd actually be able to do what you want to do.
As for an older RV - that's a tough one. Reliability is about far more than just the chassis. A 25 year old class C could be great, or not - and the mileage is only part of the story. Water damage...appliance issues...water system... all of these things can be problematic. Some would actually need to be addressed right away, others you could limp along with. Frankly, it can often be easier and faster to get the chassis issued addressed on the road than the house issues. You may find a great unit. You may not - and breakdowns for any class C, much less one of that age, are a risk.
One related concern that has not been addressed in this is the question of what you will do if you do break down and need extensive repair. No hotel is going to take in all of those animals. If your house needs to go into the shop for a few days, where do you plan to stay? From this angle, a towable could be beneficial as you'd have the option of staying in the RV while the truck was repaired, leaving you less likely to be caught without a back-up plan.
