โAug-06-2018 11:07 AM
โAug-21-2018 07:13 AM
mkirsch wrote:So people that have had sway are either dead, jackknifed, or with their rig on its side. I must be a god then (or maybe I've been dead for 15 years and didn't realize it).
If you had sway, you'd be dead now, or at least standing on the side of the road looking at your jackknifed rig laying on its side in the ditch...
โAug-21-2018 06:44 AM
โAug-19-2018 08:43 AM
โAug-13-2018 07:51 AM
Dave H M wrote:
That was a great link Barney. Super upgrade on the suspension.
But did I notice that where the rubber meets the road it was on Marathon tires? :h
โAug-13-2018 04:11 AM
โAug-09-2018 01:57 PM
โAug-08-2018 01:06 PM
handye9 wrote:
Here's a link to a calculator that might help.
There are a number of things that can cause trailer sway, main causes listed first:
Overloading, insufficient weight distribution, insufficient tongue weight percentage, towing trailer nose up, unbalanced tire pressures, tow vehicle tire sidewall flexing, mechanical (bearings, axles, struts, springs, etc) failures. If you have a sway issue, it's possible your cause is anywhere in between just one item (listed above) to a combination of all of them. Getting accurate weights and ratings on truck (curb weight, GVWR, GCVWR, and tow capacity), trailer (GVWR, actual gross weight, actual tongue weights) and hitch equipment (weight rating) is a good start. You already know, tongue weight is not a constant number, so you need to plan on it being it's heaviest.
I've heard toy haulers run heavy on the tongue (average travel trailer runs about 12 - 13 percent) to compensate for toys in the garage. So, I used 15 percent tongue weight to calculate your approximate gross weight and based on 1500 lb tongue weight I came up with 10,000 lb loaded trailer weight. That's a lot of trailer for a Tundra with 4.7 V8. Even if your Tundra's advertised max tow weight rating were 10,000 lbs, once you add a passenger or cargo (like a bike in the truck bed), it no longer has 10,000 lb tow capacity.
There are band-aids that might help with comfort, but, there is nothing you can do to increase your tow rating.
As far as moving things around in the trailer, if you get your tongue weight percentage too low, it will increase your sway issues.
Check your truck tires for a good PSI (E rated LT tires should be good for about 80 PSI). If your running lower tire pressure, you could have a little bit of sidewall flexing. Make sure they are equal in pressure. Check trailer tires for equal PSI readings
If the truck doesn't have a sway bar, maybe adding one would help with truck body twisting.
It's possible your WDH is not restoring enough weight (it's primary function) to your front axles. If your front axle has lost too much weight, you loose some steering control and create more of pivot point at the hitch. One of the main causes of trailer sway. BlueOx Sway Pro has WDH models rated for 1500 and 2000 lbs.
I too, think you may be pushing the limits on your Tundra.
โAug-07-2018 04:33 AM
jbluetooth wrote:So you want to fix a bad sway issue by adding more weight behind the axles. Man I want to be around when you test out that theory at highway speed, should be a great UTube video. Here's what happens when you move weight off the tongue and put it behind the axles. ClickyGrit dog wrote:
First, yes, move some weight rear-ward and try that. Can you not put the other bike from the truck bed into the TH? That would ease up on the truck rear axle weight significantly. Typically toy haulers are designed nose heavy to offset the "toy" weight in back.
What are you defining as sway? Some wiggling back n forth when changing lanes or correcting steering, OR uncontrollable sway that doesn't go away until you apply trailer brakes or slow back down to below a certain speed?
If you have E tires, airbags and some weight distribution, IMO the truck should handle it ok (aside from possibly being over hitch load ratings).
Thanks for the input. Its funny the things you realize when you write it down hehe. I've reloaded the trailer a bit and will drive back over to the scales to see if I'm better balanced with a lower hitch load. Maybe that's all I needed to do now that the hitch is setup better and I have the airbags. In this situation I have my standard load and the extra bike is something non-standard, which is why it ends up in the truck bed. usually I won't have it.
As for the sway, the truck tows fine in a straight line. But when I pass a semi, I get pulled into it bad enough that it's scary and I see the semi swerve a little out of the way in my rear mirror. Same thing if the wind blows, it just pushes me around more than I would like.
โAug-06-2018 08:12 PM
handye9 wrote:Toy haulers are built much like boat trailers, for the same reason. The axles are further back than on a regular camper. That gives a relatively high unloaded tongue weight (most of the weight is in front of the axles). It's also because most of the added load is expected to be behind the axles (like the weight of the engine is at the back of a motor boat), which reduces tongue weight. Because of that, just like with boat trailers, the conventional tongue weight percentage rules may not apply.
โAug-06-2018 06:54 PM
โAug-06-2018 05:17 PM
BarneyS wrote:
See this link to see pictures of the worn bushings and also what 'wet bolts" are in relation to the trailers suspension.
Barney
โAug-06-2018 05:10 PM
โAug-06-2018 02:49 PM
jbluetooth wrote:WNYBob wrote:
You don't mention the age of the trailer. Worn bushings can make sway worse..
What bushings are you referring to? The trailer is a 2008 but was barely used when I got it (60 hours on the generator). I greased all the wheel bearings and replaced the tires with Maxxis E rated before I used it. Let me know and I'll check out the bushings.
thanks!
โAug-06-2018 02:22 PM
