โOct-05-2014 01:00 PM
โOct-11-2014 11:03 AM
wa8yxm wrote:John Wayne wrote:
My guess would be it hasn't been used in awhile and had air in the propane line.
This is another one I hear all the time...
First: The furnace burns gas fast enough that if there were air in the propane line it would be blown out on the 2nd attempt and by the 3rd attempt there would only be propane in the lines.
Second: how did the air get INTO the propane lines? Some folks talk about "Well when you unhook the bottles to change/refill them" true, a teaspoon or two of air can get in then.
But I grew up with propane, 3 different systems on the farm, One for the house, one for the other house one for the milkhouse, and not one of them ever had that problem even when we detached the 100 pound bottles and took them to town (Actually 3 or 4 towns over), not the nearest town) and back to re-fill them and brought them back.
IT all worked fine, Never had so much as a water heater go out due to air in the lines.
One system was a space heater (In fact two were)
One was a water heater and kitchen stove/oven.
Not one of them ever had air-in the line problems.
โOct-11-2014 06:12 AM
โOct-11-2014 05:07 AM
CampingN.C. wrote:I'd suggest to break out the air hose again and this time direct it into the intake port. You could also blow back through the exhaust to make sure any debris is moved out of the ignition area.Chris Bryant wrote:
Sounds to me like a pinched copper line, or a bit of debris in the orifice- a restriction to the LP flow.
I think you nailed it. I thought I had it going but it started to act up again. I called the dealer today and before I fully explained the symptoms he said it was debris, which is odd because it's been in a garage all summer, but that's my luck.
Of course it's not covered under the warranty. And of course it cannot be removed from the exterior, lovely !!
โOct-10-2014 04:57 PM
โOct-10-2014 01:09 PM
โOct-07-2014 06:01 AM
โOct-07-2014 04:25 AM
John Wayne wrote:
My guess would be it hasn't been used in awhile and had air in the propane line. The heater will try and light 3 times then turnoff and you need to turn off the thermostat and start all over again. When I say tries to light 3 times you will be able to hear the igniter light the flame it will burn for for a few seconds then go out it will do this for 3 times and if the flame doesn't keep going you will have to turn it off and start all over till all the air gets out then it will work with no problems until it has sat for an extended time and air has gotten in the propane line. Been there done that.
โOct-06-2014 03:09 PM
โOct-06-2014 08:56 AM
sch911 wrote:
Sounds like a bad sail switch.
โOct-06-2014 07:22 AM
kaz442 wrote:There are two types of electronic ignition. One type uses a intermittent pilot light. So you can have electronic ignition and a pilot light. Depends on the manufacturer.
Pilot light? This is a 2014? Really?
My junk is an 1989 and has electric ignition on heater and hot water.
โOct-06-2014 04:34 AM
โOct-06-2014 02:45 AM
โOct-05-2014 06:52 PM
โOct-05-2014 06:15 PM
