Pam cooking spray
slides
I've read some of you fine folks spray Pam on the front of your RV's to help in cleaning bugs off of your front cap. Does it affect the decals (making them turn loose or become brittle)after a long time?
2012 F-350 King Ranch 6.7 Turbo Diesel
2009 31SB Cardinal 5er
Use And Promote CB Channel 13
30 REPLIES 30
wanderingbob
I have wrapped the front with shrink wrap . Worked pretty good , peeled off easy .
I took it off every day as I did not know what would happen long term . I do not know what that stuff costs as it came with the job !
Dutch_12078
MPI_Mallard wrote:
...as WD40 is mostly fish oil and water it rinsed off without a trace, try it!!
Myth: WD-40 contains fish oil.
Fact:
Consumers have told us over the years that they have caught some of the biggest fish ever after protecting their fish hooks and lures with WD-40. We believe this legend came from folks assuming that the product must contain fish oil since it appears to attract fish. Sorry Charlieยฎ, it just ainโ€™t so.
http://wd40.com/about-us/myths-legends-fun-facts/
MSDS for petroleum based WD-40:
http://www.wd40company.com/files/pdf/msds-wd494716385.pdf
Dutch
2001 GBM Landau 34' Class A
Scott_85
The dollar general version of the magic easer worked wonders for me.
TV: 2013 Ram 2500 Laramie, G56, Andersen Ultimate 5th Wheel Hitch.
5er: 2013 Coachmen Chaparral 280RLS
shutdown
MPI_Mallard wrote:
I was told (now get this) that WD40 was good for removing the bugs off my front cap and after after returning home from florida,,,It did work,,,,very well actually, they literally slid off the cap after a 20 minute soak which at that point I washed the cap off with my regular car-wash soap and as WD40 is mostly fish oil and water it rinsed off without a trace, try it!!
Red Green;
If it moves and it shouldn't, duck-tape,
if doesn't move and it should,WD40!!
Just an FYI WD40 is NOT fish oil. It is a petroleum product. Not a huge deal i think with a proper wash it will be OK to clean end caps but don't go applying it to seals...just like any petro product it will cause them to degrade.
pasusan
sgrizzle wrote:
can yoy use the collinite over the decals?
I have used the Collinite wax for years and yes, over the decals - all are still like new. You can get the stuff on Amazon.
Susan & Ben [2004 Roadtrek 170]
href="https://sites.google.com/view/pasusan-trips/home" target="_blank">Trip Pics
2012Coleman
Put a good wax job on it. I'm going to try the wet dryer sheet - never have done so yet.
2018 RAM 3500 Big Horn CTD
MarshaNichols
austinjenna wrote:
Second the dryer sheets....I wet down the front cap...use wet dryer sheets....very little rubbing and they all come o
X2 on the dryer sheets
Yes, they work, but do put very tiny scratches ... a little wax helped
sgrizzle
Woody69
noplace2 wrote:
Forget the vegetable spray, you'll attract more dirt than anything. The magic answer for bug removal is wet dryer sheets. You will be amazed.
Yep ! They work great !
2004 31' Gulf Stream Prairie Schooner 5er
BubbaChris
And for in the kitchen Vegalene is a superior product to Pam and the generics, especially with non-stick cookware. Easiest and cheapest for a non-stick pan is to pour a little high-temp oil like canola in first and then wipe out all you can with a paper towel.
2013 Heartland North Trail 22 FBS Caliber Edition
2013 Ford Expedition EL with Tow Package
Bears_Den
Traveled from home to FW last week, the love bugs were bad. Wet dryer sheets did wonders. When I got home I used one of those sponges with the nylon on them and it worked wonders also.
2014 Kodiak 279 rbsl
2017 Ford F-150 King Ranch V8
Equalizer hitch
Ford integrated brake controller
2004 Travel Lite 23S Hybrid Travel Trailer ( previous trailer )
1998 Viking Popup ( previous trailer )
No substitute for experience
slides
Do the dryer sheets not strip the wax
kully
hi we have a full body paint brookstone a guy showed me this wax called Collinite NO. 845 I did all of 5th wheel just took on a 1,100 mile trip came back front was loaded with bugs ,used car wash and ever bug came off I was very surprised ,it works GREATT I have used a lot of different wax on other camper but I will stay with this . Advanced auto sells it for 17.95 they don't stock it but can order it in .
wa8yxm
WD-40 is many things, Water Displacement Formula 40 (makes me wonder what happened with Formulas 1 through 49 inclusive).
It is a cleaner, a penetrant (penetrating Oil) it is not a long-term lubricant.. Other products do that job better.
Oh, and it displaces water.
