Pam cooking spray
slides
I've read some of you fine folks spray Pam on the front of your RV's to help in cleaning bugs off of your front cap. Does it affect the decals (making them turn loose or become brittle)after a long time?
2012 F-350 King Ranch 6.7 Turbo Diesel
2009 31SB Cardinal 5er
Use And Promote CB Channel 13
30 REPLIES 30
blkdodge
One thing I have not heard mention is on a full body paint. I guess they don't attract the bugs, EXCEPT MINE.
2012 Dodge 3500 DRW/2012 Heartland Landmark San Antonio.
ol_Bombero-JC
MPI_Mallard wrote:
....... and as WD40 is mostly fish oil and water.....
if doesn't move and it should,WD40!!
Partial hi-jack.
WD40 has more solvent properties than lubricating properties.
No need to waste WD40 on a front cap.
Many better choices for - "if it doesn't move and should" things:
SeaFoam Deepcreep
Kano Aerokroil
Zep 45 yellow label
Drummond American Open & Shut
JB 80
WD40 (but not for bugs)
etc. -
but easiest (and cheapest) is 50/50 mix of ATF & Acetone.
For a quick temporary fix - "Racer Tape" (duct tape) is ugly, but does well.
Depending on what you are "fixing" - JB Weld is lots better.
Back to BUGS:
......DO NOT "PAM it"!
Red Max Pro (or Zep) coating - wash and used dryer sheets for stubborn bugs.
Don't want to (or didn't) wax or do the RMP or Zep?
Just wash & used dryer sheets for the bug removal.
Works great for your auto/s & trucks too - used dryer sheets won't harm the finish...:C
Vulcaneer
WD40 before. And water soak and wash with good soap, and dryer sheets, then a final wash and rinse. Bugs are gone.
'12 F350 SB, CC, SRW, 6.7 PSD, 3.55 RAR, 6 spd auto
2015 DRV 38RSS 'Traditions'
Pullrite Super Glide 18K
Retirement = It's all poops and giggles....UNTIL someone Giggles and Poops.
remdog_1
Rejex wax
tomkaren13
Take from a detailer in Florida. Soaking with just water soon after you stop. Wait a few minutes and a nylon or plastic scrubby will work very well on Lovebugs. The key word here is "soon". Overnight is not soon.
travelnutz
Hey, the Pam butter flavor spray works great on the RV roof too especially in the southern states the the southwest. Great for frying eggs, pancakes, American Fries, and they never stick!
A superb CC LB 4X4, GM HD Diesel, airbags, Rancho's, lots more
Lance Legend TC 11' 4", loaded including 3400 PP generator and my deluxe 2' X 7' rear porch
29 ft Carriage Carri-lite 5'er - a specially built gem
A like new '07 Sunline Solaris 26' TT
bound4fl
austinjenna wrote:
Second the dryer sheets....I wet down the front cap...use wet dryer sheets....very little rubbing and they all come o
X2 on the dryer sheets
X3 along with good wax job to start
Killin time waitin on tomorrow.
austinjenna
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
cpaulsen
Second the dryer sheets....I wet down the front cap...use wet dryer sheets....very little rubbing and they all come off.
cpaulsen
TXiceman
If you spray Pam or like on the front, and you let it set fro a couple of days in the sun, it turns to a goo that is a real chore to wash off.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
dons2346
Spray some of that junk on a piece of sheet metal and see how it feels in a few days. You will change your mind.
noplace2
Forget the vegetable spray, you'll attract more dirt than anything. The magic answer for bug removal is wet dryer sheets. You will be amazed.
โ€˜Love is whatโ€™s in the room with you if you stop opening presents and listen.โ€™ - Elain - age 8
MPI_Mallard
I was told (now get this) that WD40 was good for removing the bugs off my front cap and after after returning home from florida,,,It did work,,,,very well actually, they literally slid off the cap after a 20 minute soak which at that point I washed the cap off with my regular car-wash soap and as WD40 is mostly fish oil and water it rinsed off without a trace, try it!!
Red Green;
If it moves and it shouldn't, duck-tape,
07' Dodge 3500 6 speed Cummins Diesel Dually/6.7L Bully-Chipped /
Exhst Brake/07' Cedar Creek 37CDTSD Daydreamer fiver
Mallard @ Frau Blรผcher
Red Green:
Now lets Bow your heads for the men's prayer.
I am a man, but I can change.
If I have to, I guess...
Cuffs054
Slides, a funny (not) story, got my first Cadillac saved for years. Sprayed front e nd with Pam to ward off lovebugs. Amazing how much having front end repainted lowered trade in value. I'm just sayin...
sch911
I use the butter flavor, seems to attract more bugs. :B
OEM Auto Engineer- Embedded Software Team
09 Holiday Rambler Endeavor 41SKQ Cummins ISL
2012 Jeep Grand Cherokee Limited Toad
