Portable fire pit propane usage & models
chracatoa
Any suggestions for a portable propane campfire?
Also, how much propane would I use per hour for a small one (like Little Red Campfire or Heininger 5995. I don't want to deplete the tanks...
2011 Toyota Sequoia Platinum 4WD 5.7L V8 (next one will be a 3/4, someday)
2012 Jayco Flight Swift 267BHS (5963lbs dry, 6850 wet)
Propride hitch (I had a Reese dual cam round bar WDH for 4 months)
22 REPLIES 22
JiminDenver
We have the one from Lowes for $99 and love it.
2011 GulfStream Amerilite 25BH
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 2200w inverter generator
MitchF150
Here is my Fire Dancer. I've had it for years and works great when you don't want or can't have a real fire.
It doesn't use much propane at all. You can adjust the flow and regulate how much fire you want.
I use your standard "20lb" cylinder and I get a lot of hours out of it.
2013 F150 XLT 4x4 SuperCab Max Tow Egoboost 3.73 gears #7700 GVWR #1920 payload. 2019 Rockwood Mini Lite 2511S.
IAMICHABOD
I like the Heininger better,It is larger and puts out much more heat and it does really look like a real fire unlike the tin can one.
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
bob213
Fresno Tundra Driver wrote:
Campfire in a Can. Its the best by far. It gives off the most warmth and looks like a natural wood fire. With a five gallon propane tank you'll get anywhere from 12-20 hours of fire depending on the setting.
X2
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ€“ Ayn Rand
WyoTraveler
I purchased the one at Lowes. $99. I can use it off of a propane bottle and also connects to my MH tank. Just have to change the hose fitting. Propane dealer made me up another hose.
Fresno_Tundra_D
E.Lee Galik
Wet_Coast
Rule of thumb is 20,000 btu /hr = 1 lb of propane.
04 3500 4X4 Auto Cummins QC
Onboard air, Air bags, Pac Brake
05 Cougar 244EFS, Flexair Pin Box, Dexter Equalizers
6x6v, 900watt, 60a Renology MPPT, 2200w Xantrex, 3500w IPower Genset
VA7RKC Advanced
Everything runs on smoke, don't let the smoke out
yrusoslo
Lowes & Home Depot have a good selection
