Question about exiting in an emergency
harryjr
The deadbolt latch on the door of my Eagle is small, black, recessed and can be covered by the bug shield. If I haven't had my coffee in the morning I fumble and stumble trying to unlock it.
So what happens if it's the middle of the night and I've got flames licking my a$$. Brick and mortar building codes require panic bars. The dead bolts on a house are larger and prominent. Why is an RV different? I can't imagine trying to exit through the emergency window exit, and basic firefighting procedure whenever possible is to "take 'em out the same way they went in.
Why isn't it a RVIA standard to make unlocking the deadbolt more user friendly in an emergency?
Harry Jr.
Southeastern CT
36 REPLIES 36
Dutch_12078
Why would you lock the deadbolt when you're inside the RV?
Dutch
2001 GBM Landau 34' Class A
Grit_dog
Navigator
Navigator
harryjr wrote:
I apparently worded my initial post poorly. I know to get out as early as possible, as quickly as possible, by any means possible.
My question is: Why isn't the exit designed by the manufacturer to be more user friendly for the poor victim who is confused, not prepared, incapacitated, or a minor? The exit procedure should be simple and intuitive.
Since idiot proof is impossible, at least make it idiot helpful.
It's also not ADA compliant. Should all RVs be ADA compliant as well?
Seriously, find something else to worry about.
dedmiston
Moderator
Moderator
I agree with all the comments that you shouldn't close that bug door when you close your outside door. That should only be closed when you're just closing the screen but leaving the door open. Hopefully the deadbolt isn't too hard to operate with that bug door open.
I'm also in the camp that leaves some basic clothing and shoes in the same spot every night. Coincidentally, I drape those clothes right over the fire extinguisher we keep in our room.
And I completely agree with the rest of the comments about leaving your coach through any means possible. Just get out.
2014 RAM 3500 Diesel 4x4 Dually long bed. B&W RVK3600 hitch โ€ข 2015 Crossroads Elevation Homestead Toy Hauler ("The Taj Mahauler") โ€ข <\br >Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
CFerguson
If theres a fire, i'll be kicking out any window/door that gets in my way the slightest bit. No way cheap trailer construction will stand up to that. Yeah, thats it- RVs are designed and constructed for rapid exiting for Safety Purposes.
rhagfo
Lwiddis wrote:
When you check the lock just before retiring, move the bug shield over.
X2
No need for the bug cover when the door is closed.
mgirardo
harryjr wrote:
My question is: Why isn't the exit designed by the manufacturer to be ore user friendly for the poor victim who is confused, not prepared, incapacitated, or a minor? The exit procedure should be simple and intuitive.
How could it be made simpler? Turn a lever, open door. How is that any more difficult than at your house? On ours, the dead bolt lever is red and pretty big. Easy to see if flames are licking my backside.
-Michael
Michael Girardo
2017 Jayco Jayflight Bungalow 40BHQS Destination Trailer
2009 Jayco Greyhawk 31FS Class C Motorhome (previously owned)
2006 Rockwood Roo 233 Hybrid Travel Trailer (previously owned)
1995 Jayco Eagle 12KB pop-up (previously owned)
time2roll
thomasmnile wrote:
I'm thinking one swift kick and the door will open......
+1
Not even going to attempt the window.
harryjr
Harry Jr.
Southeastern CT
Sjm9911
wa8yxm wrote:
If the RV is on fire you have SECONDS to get out (more in a bit as to why) the succestion is go out the escape window. there should be one over the bed and likely on on the other side. First person goes out feet first. Lay bedspread over edge of window and drop 2nd person dives into first person's arms GET OUT FAST.
Why Fast.. Much of what goes into making an RV burns TOXIC..
TOXIC means you don't have to inhale much before you are no more.
(Both faster and more deadly than simple poison).
TV show: Crossing Jordan.. Plane crashed (Everybody dead BEFORE crash)
A battle between a criminal and Law Enforcment (Air Marshall) caused a gun shot to the lead acid battery on a wheelchair.. Acid mixed with carpet. all dead passengers and crew. The plane eventually crashed.
I might add. that type of battery is no longer allowed on flights.. That is also why.
Well that was a bit of Fiction (A TV show) but it illustrates the point.. IN real life burning RV carpet. Upholstery and seats.. NOT GOOD FOR YOUR HEALTH.
The idea is that the smoke alarm goes off before there is a raging fire in the camper and you walk out. Everything that burns is basicly toxic.
2012 kz spree 220 ks
2020 Silverado 2500
Equalizer ( because i have it)
Formerly a pup owner.
wa8yxm
Sjm9911
The idea of the panic bar and such is for things you are unfamiliar with or with places with lots of people inside. Thats why there not on say a pizza joint but will be in your home depot etc. The rv latch is yours and with time you will be able to open it in your sleep. Make sure your smoke and lp/co detectors work and you should have 0 problems with lead time to escape.
2020 Silverado 2500
spoon059
In an emergency, I'm going THROUGH that styrofoam door.
2015 Ram CTD
2015 Jayco 29QBS
valhalla360
Nomad III
Nomad III
Guy Roan wrote:
Leave it unlocked !
Guy
Yep, pretty much never lock the door when we are inside.
Also, don't get why you would close the bug cover while inside with the main door closed.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Guy_Roan
Leave it unlocked !
Guy
MrWizard
Moderator
Moderator
Why would I close the bug slide on the screen door
When the entry door is closed and locked
I DON'T
the dead bolt is a lever instead of knob
But it works easy
My bedroom Windows are marked exit, and are big enough to go out, they slide open
Panic is what will kill you,
Yes do hurry, but DON'T PANIC
I can explain it to you.
1997 F53 Bounder 36s
