question about low point drain and winterizing
tim1970
We are taking the 5er out this weekend, and hopefully we don't have to worry about winterizing again since we live in N.E. Texas. However, if the forecast calls for it, I have no problems doing it. My question is this: Since I use my air compressor set on 30lbs to blow out my lines, do I have to worry about the low point drains, or is this just for draining the lines when not blowing them out?
Also, since I keep my 5th wheel at my house and have a 50 amp plug, could I just turn on the furnace on the lowest setting if the forecast called for freezing temps?
2017 Jayco 29.5 BHDS
5 REPLIES 5
old_guy
you will run out of propane in a hurry running it 24/7
wnjj
TenOC wrote:
Winterizing is cheaper (and only takes few minutes) than furnace.
Winterizing is cheaper, but turning on the heat (or a space heater) is faster. It depends upon if you have spare time or spare money I suppose. You also may not end up needing the heat but you canโ€™t take back the time you spent rewinterizing.
TenOC
Please give me enough troubles, uncertainty, problems, obstacles and STRESS so that I do not become arrogant, proud, and smug in my own abilities, and enough blessings and good times that I realize that someone else is in charge of my life.
Travel Photos
BB_TX
Just blow out the low point drains after you blow out all the other lines. Just takes a few seconds.
ScottG
Yes, you still have to drain them because water gets trapped in them.
And yes, the furnace should protect everything - at least in theory.
